FURUTECH FI-8N NCF Rhodium Plated Beryllium Copper IEC C7 Connector NCF Alpha Treatment Ø13mm
This Furutech FI-8N connector, resolutely top of the range, has an exceptional design to ensure the highest performance. It includes Rhodium-plated Beryllium Copper contacts and Alpha treatment as well as a body integrating the NCF material.
Reference : 13860
81,00 €tax incl.
67,50 € tax excl.
Shipping date: 24-04-2025.
Furutech FI-8N NCF
Furutech FI-8N NCF Connecteur IEC C7 Cuivre Béryllium Plaqué Rhodium NCF Traitement Alpha Ø13mm
A resolutely high-end IEC C7 connector, the Furutech FI-8N benefits from an incredibly high quality design, using the best materials to ensure the highest performance. Thus, the connector contacts are made of Copper Beryllium with Rhodium plating and α (Alpha) treatment. This treatment consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect.
Product typeIEC C7 Connector
Contacts materialRhodium Plated Béryllium Copper
Contacts treatmentα (Alpha)
Shell materialNylon Fiberglass, NCF
Min / Max Cable diameter6mm / 13mm
Max conductor diameter2.4mm (solid core)
Max conductor section2mm² / 14AWG (multi strands)
Connection typeTo screw
Dimensions36.8 x 28.2 x 71mm
Weight51g
Max cable diameter (mm)13.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C7
Contacts Material (Connector)Beryllium Copper
Rated current (A)N/A
This Furutech FI-8N connector, resolutely top of the range, has an exceptional design to ensure the highest performance. It includes Rhodium-plated...
