IEC LOCK EC60320-C13 Lockable IEC C13 Connector 250V 15A Ø8mm
This IEC Lock connector in IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An effective locking system prevents cables from accidentally detaching from the devices to which they are connected.
Reference : 17897
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 16-04-2025.
IEC Lock IEC60320-C13
IEC Lock IEC60320-C13 Connecteur IEC C13 verrouillable 250V 15A Ø8mm
This IEC Lock connector in IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An effective locking system prevents cables from accidentally detaching from the devices to which they are connected. IEC Lock connectors are fully compatible with standard IEC connectors and require no additional modifications or special cables. Mounting is simple, with a screw-on system that requires no soldering.
Product typeLockable IEC C13 connector
IEC formatIEC C13
Shell materialNylon LSZH
Min/Max conductors section0.75mm² - 1.5mm² (14AWG - 18AWG)
Max cable diameterØ8mm
Voltage / Current250V 15A
Operating temperature range-25°C / +70°C
CertificationsKEMA
ENEC 05
UL
Dimensions75*26*20.3mm
ColorBlack and red
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Contacts Plating (Connector)N/A
Rated current (A)15.0
très bien
sytème de blocage efficace, pour la section du câble se limiter au 3x 1,5 mm2 mais largement suffisant pour beaucoup d'appareils
This review has been posted for IEC LOCK EC60320-C13 Lockable IEC C13 Connector 250V 15A Ø8mm
This IEC Lock connector in IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An...
