IEC LOCK U/D Lockable IEC C13 Connector Angled 250V 15A Ø8mm
This IEC Lock connector in angled IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An effective locking system prevents cables from accidentally detaching from the devices to which they are connected.
Reference : 17900
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 16-04-2025.
IEC Lock U/D
IEC Lock U/D Connecteur IEC C13 verrouillable coudé 250V 15A Ø8mm
This IEC Lock connector in angled IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An effective locking system prevents cables from accidentally detaching from the devices to which they are connected. IEC Lock connectors are fully compatible with standard IEC connectors and require no additional modifications or special cables. Mounting is simple, with a screw-on system that requires no soldering.
Product typeLockable IEC C13 connector
IEC formatAngled IEC C13
Shell materialNylon LSZH
Min/Max conductors section0.75mm² - 1.5mm² (14AWG - 18AWG)
Max cable diameterØ8mm
Voltage / Current250V 15A
Operating temperature range-25°C / +70°C
CertificationsKEMA
ENEC 05
UL
Dimensions60.5*38*21mm
ColorBlack and red
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Contacts Plating (Connector)N/A
Rated current (A)15.0
This IEC Lock connector in angled IEC C13 format offers an innovative solution designed to ensure secure, reliable connection of power cables. An...
