This IEC C13 Neotech NC-P303II connector will enable you to design your own high-performance cables. It incorporates G-UPOCC composite contacts, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Furthermore, in order to guarantee perfect conductivity while offering flawless protection against corrosion and oxidation, the NC-P303II contacts are double-plated, first in silver, then in gold. Finally, this connector has been cryogenically treated, further improving its conductivity.
Product type | IEC C13 connector |
Contacts material | G-UPOCC Copper |
Contacts plating | Silver Gold |
Max cable diameter | Ø24mm |
Max conductor section | 5.5mm² |
Cryogenic treatment | |
Mounting type | To screw |
Dimensions | Ø40 x 80mm |
Package | Sold by unit |
Max cable diameter (mm) | 24.0 |
Connectic | Female |
Connector | IEC C13 |
Contacts Material (Connector) | Copper |
Contacts Material (Connector) | Graphene |
Contacts Plating (Connector) | Gold |
Contacts Plating (Connector) | Silver |
Rated current (A) | N/A |
