RAMM AUDIO IEC-01 Power Connector IEC C15 24K 3µ Gold Plated Ø16.5mm Transparent
Ramm Audio's IEC-01 is an IEC C15 power connector with a high-quality, transparent nylon body. Aesthetic and solid, this chassis is perfectly suited to the integration of sophisticated, high-end cables. Its proportions make it ideal for large-diameter cables and conductors.
Reference : 17861
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 17-04-2025.
RAMM AUDIO IEC-01
RAMM AUDIO IEC-01 Connecteur Secteur IEC C15 Plaqué Or 24K 3µ Ø16.5mm Transparent
This connector accepts cable diameters up to Ø16.5mm. Thanks to a rubber cable clamp, your large cross-section cables will be securely held in place. The contacts are cryogenically treated and plated with 3µ thick 24k gold for maximum conductivity and resistance to oxidation and corrosion.
Finally, it's worth noting that the internal connection terminals feature large fixing screws and a particularly large contact surface. No soldering is required to integrate your cable, and large-diameter conductors are firmly held in place.
Product typeIEC C15 power connector
Mounting typeTo screw
Max cable diameterØ16.5mm
Max conductors section16mm² (Ø4.5mm diameter)
Contacts treatmentCryogenic
Contacts platingGold 24k 3µ
Voltage /Current250V 16A
DimensionsØ38*80mm
Weight60g
ColorTransparent
Max cable diameter (mm)16.5
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
Ramm Audio's IEC-01 is an IEC C15 power connector with a high-quality, transparent nylon body. Aesthetic and solid, this chassis is perfectly...
