SCHURTER Connector IEC C13 angled Ø8mm
Reference : 9559
4,50 €tax incl.
3,75 € tax excl.
Shipping date: 22-04-2025.
Connector IEC C13 SCHURTER 4785 Elbow Ø8mm
IEC female plug, high quality, German made, RoHS certified.
Black nylon body with high heat resistance (up to 70 °).
The 3 conductors with a maximum cross-section of 2.5mm² are secured with 3 screws (2 poles + ground).
Compatible with cables up to 8mm in diameter.
Features:/ Strong>
  • Brass Contacts
  • Black Nylon Body
  • Fiche à Visser
  • Compatible with cables of Ø 8mm Max.
  • Current / Voltage: 250V / 10A
  • Temperature Range: -25 ° to 70 °
  • Body Length: 62mm
  • Dimensions: 87.5x28.7x21mm (L x W x H)
  • Approved: UL, CSA, VDE, BSI
  • RoHS Certified
https://www.audiophonics.fr/images2/5082/5082_IEC90D4785_1.jpg
https://www.audiophonics.fr/images2/5082/5082_IEC90D4785_2.jpg
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Rated current (A)10.0
accessoire très utile
Accessoire très pratique pour réaliser soi-même des cordons sur mesure (longueur, couleur câble,...)
Prix très correct .malgré la rareté de cet accessoire . Devrait être facilement disponible en d'autres normes .
This review has been posted for SCHURTER Connector IEC C13 angled Ø8mm
