VIABLUE T6s IEC C19 Power Plug Gold Plated 24K Ø16mm
Reference : 11539
122,99 €tax incl.
102,49 € tax excl.
viablue ts 6 IEC C19The high-end C19 mains plug Viablue T6sis distinguished by its scratch-resistant ULTRAGRIP coating with the finest satin finish.
Its internal diameter of 16mm allows to receive the most sophisticated sector cables whose size often proves incompatible with the conventional electrical outlets.
Its double screw fixing with a mounting system of different diameters ensures a reliable mechanical maintenance over the long term for the cables of large section.
The polycarbonate exterior body of this high-end AC outlet features a flame retardant and high impact resistance.
All metal parts, including the contact poles, benefited from a plating Gold 24k.
This plating present on the whole surface of the contacts is more resistant and better conductor than the plating Standard gold, against any form of oxidation. The electrical behavior of the characteristics is therefore maintained even after many years of operation.
Specifications:
  • Plated contacts 24K Gold
  • C19 Connectors 3 Screw Connectors
  • Maximum cable diameterthe :from 6mm to 16mm
  • Viablue surface ULTRAGRIP scratch resistant
  • Double centering decreasing Soft-Disc-Technology
  • Voltage / Voltage Rating: 16A / 230V
Dimensions:
  • Overall Length: 93 mm
  • Outside diameter max: 40 mm
VIABLUE T6S C19
IEC Plated 24K Gold Connector
Viablue T6S Series (sold separately)
viablue ts 6 IEC
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C19
Rated current (A)16.0
