VIABLUE T6s IEC C7 Power Plug Gold Plated 24K Ø16mm
Reference : 11526
116,99 €tax incl.
97,49 € tax excl.
Shipping date: 25-04-2025.
viablue TS6 C7The high-end C7 mains plug Viablue T6sis distinguished by its scratch-resistant ULTRAGRIP coating with the finest satin finish.
Its internal diameter of 16mm allows to receive the most sophisticated sector cables whose size often proves incompatible with the conventional electrical outlets.
Its double screw fixing with a mounting system of different diameters ensures a reliable mechanical maintenance over the long term for the cables of large section.
The polycarbonate exterior body of this high-end AC outlet features a flame retardant and high impact resistance.
All metal parts, including the contact poles, benefited from a plating Gold 24k.
This plating present on the whole surface of the contacts is more resistant and better conductor than the plating Standard gold, against any form of oxidation. The electrical behavior of the characteristics is therefore maintained even after many years of operation.
Specifications:
  • Plated contacts 24K Gold
  • C7 Connectors 2 Screw Connectors
  • Maximum cable diameter:from 6mm to 16mm
  • Viablue surface ULTRAGRIP scratch resistant
  • Double centering decreasing Soft-Disc-Technology
  • Voltage / Voltage Rating: 16A / 230V
Dimensions:
  • Overall Length: 92 mm
  • Outside diameter max: 40 mm
VIABLUE T6S C7
IEC Plated 24K Gold Connector
viablue TS6 C7
Viablue T6S Series (sold separately)
viablue ts 6 IEC
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C7
Rated current (A)16.0
Qualité remarquable
La plus chère en format IEC7 de ce site mais justifiée par sa qualité de fabrication . Extérieurement un fin revêtement caoutchouté bien intégré à la prise permet une meilleure isolation vibratoire . Intérieurement un lot de bagues est à clipser en fonction du diamètre de votre câble (plus pratique que les autres marques de ce site ) . Un son très équilibré et transparent sans agressivité . Recommandable.
This review has been posted for VIABLUE T6s IEC C7 Power Plug Gold Plated 24K Ø16mm
