VIBORG VF502G IEC C15 Connector Silver / Gold 24k Plated Pure Copper Ø20mm
This IEC C15 connector Viborg VE502G is ideal for creating high quality power cables. It uses very good components, allowing both to promote conductivity but also to offer this connector a very good longevity. The contacts are made of pure Copper with triple plating: OFC Copper, Silver, 24k Gold.
Reference : 13165
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 15-04-2025.
Viborg VE502G
IEC C15 Connector Silver / Gold 24k Plated Pure Copper Ø 20mm
Viborg VF502G Connecteur IEC C15 Cuivre Pur Plaqué Argent / Or 24k Ø 20mm
This IEC C15 connector Viborg VE502G is ideal for creating high quality power cables. It uses very good components, allowing both to promote conductivity but also to offer this connector a very good longevity. The contacts are made of pure Copper with triple plating: OFC Copper, Silver, 24k Gold. In addition, this connector is able to accommodate cables up to 20mm in diameter and will therefore be suitable for both "classic" cables and HiFi cables with a larger diameter. Finally, the connector is covered with an Aluminium alloy body. This allows both to offer the connector a beautiful design but above all to limit EMI / RFI interference that could damage the signal and therefore audio reproduction.
Connector typeIEC C15
Contacts materialPure copper
Contacts plating1. OFC Copper
2. Silver
3. Gold 24k
Max cable diameterØ 20mm
Max. conductor diameter / cross-section4.5mm
Voltage / Current250V AC / 16A
Dimensions81.5 x 40mm
ScrewHexa / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
6 reviews
bon connecteur
bon connecteur, j’ai été surpris par le contact trés franc que l’on sent lorsqu’on insére la prise. C’est bien contruit. Le connecteur est massif et lourd, malgré tout il tient en place sans support.
Pour le son difficile de se prononcer par rapport à un connecteur pur cuivre.
This review has been posted for VIBORG VF502G IEC C15 Connector Silver / Gold 24k Plated Pure Copper Ø20mm
Excellente
Remarquable en qualité audio (neutralité et définition), toutefois assez longue et lourde : attention requise si le dégagement derrière l'appareil est insuffisant ou si l'embase recevant le connecteur est peu profonde (celui-ci aura tendance à glisser vers le bas).
Complémentarité
Ce connecteur IEC en cuivre argent or est complémentaire d'un câble d'alimentation en cuivre équipé d'une prise shuko Elecaudio également en cuivre argent or. J'avais un connecteur IEC Elecaudio mais en alliage de cuivre. Le montage est plus cohérent ainsi que le son.
IEC Viborg 502 G
Très bon rapport qualité prix. Le connecteur est de qualité exemplaire pour le prix. Au niveau du son , il est équilibré . Aucun registre est mis de l’avant comme j’ai pu le constater avec d’autres connecteurs .il demande un certain temps de rodage pour s’assouplir mais il est déjà très bon dès le départ . Ces commentaires s’appliquent aussi aux connecteurs schuko de la même marque et série . Cette série amènent plus d’assise que les connecteurs Viborg 501 .
Nickel
Montés sur Furutech FP-3TS762 et FP-TCS31, ils laissent le message musical s'exprimer en toute transparence, aucun registre mis en avant. Comparés à des connecteurs Charlin, ils sont largement au même niveau .
Excellents !!!!
This IEC C15 connector Viborg VE502G is ideal for creating high quality power cables. It uses very good components, allowing both to promote...
