VIBORG VF503 IEC C15 Connector Pure Copper Ø19mm
The IEC C15 Viborg VF503 connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The connector's contacts are made of pure Copper, a material that provides excellent electrical conductivity.
Reference : 14317
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 23-04-2025.
Viborg VF503
Viborg VF503 Connecteur IEC C15 Cuivre Pur Ø19mm
The body of the connector is made of Bayer-2805 Polycarbonate. The conductors are simply inserted into the connector by means of a screw system that holds the conductors firmly in place.
Product typeIEC C15 Connector
Contacts materialPur Copper
Body and contacts support materialPolycarbonate Bayer-2805
Mouting typeTo solder (hex screws)
Max conductors diameterØ8mm
Min/Max cable diameterØ6mm / Ø19mm
Voltage / Current250VAC 10A
Total dimensions77 x Ø40mm
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)10.0
5 reviews
Superb design, excellent quality
This review has been posted for VIBORG VF503 IEC C15 Connector Pure Copper Ø19mm
Excellente qualité
Excellente fiche IEC qui vaut bien son prix. Permet de confectionner des câbles d'excellente qualité audio. Combinée à une prise Schuko ELECAUDIO PS-24RA et à un câble 3 X 1,5 blindé Elecaudio j'ai obtenu une différence de qualité nettement audible par rapport au câble d'origine. Surprenant mais la dépense valait la peine !
satisfied with the upgrade
I've purchased together with VIBORG VE503 Schuko Power Connector Type E/F Pure Copper Ø19mm, and install it on an Elephant cable, to replace the power cable of a power amplifer. The results are: more defined bass, overall natural musical sound, wormer, separated voice, distinctive instruments. A better stereo imagine and increased soundstage on all axes. Very satisfied with the upgrade
parfait .
dans l esprit de rester tout cuivre j ai acheté cette fiche .
rien à redire.
bonne qualitée apparente meme si je doute que le corps de la fiche resiste à plusieurs chutes ou choques ?
accepte du câble plus gros que 2,5 mm .
montage sans difficulté et prix acceptable .
bravo .
Excellent produit...
J'ai reçu l'article dans une petite boîte.
Le plastique autour de la fiche laisse une impression de "fragilité" mais le produit reste qualitatif.
J'ai associé ce connecteur IEC au connecteur Schuko de la même marque et aux câbles Neotech UP-OCC Cuivre ; Et le gain est au rendez-vous : plus aéré et plus précis.
Je voulais avoir 100% de cuivre depuis mon transfo d'isolement à mon équipement hifi et je ne regrette clairement pas mon investissement.
The IEC C15 Viborg VF503 connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi...
