VIBORG VF503G IEC C15 Connector Pure Copper Plated Silver / Gold 24k Ø19mm
The IEC C15 Viborg VF503G connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The connector's contacts are made of pure Copper, a material that provides excellent electrical conductivity.
4.2 / 5
Reference : 14318
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 23-04-2025.
Viborg VF503G
Connecteur IEC C15 Cuivre Pur Plaqué Argent / Or 24k Ø19mm
Viborg VF503G Connecteur IEC C15 Cuivre Pur Plaqué Argent / Or 24k Ø19mm
The IEC C15 Viborg VF503G connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The connector's contacts are made of pure Copper, a material that provides excellent electrical conductivity. These contacts benefit from a triple plating of OFC Copper, Silver and 24k Gold to maximize conductivity while improving their resistance to oxidation.
The body of the connector is made of Bayer-2805 Polycarbonate. The conductors are simply inserted into the connector by means of a screw system that holds the conductors firmly in place.
Product typeIEC C15 connector
Contacts materialPure copper
Contacts platingOFC Copper
Silver
24k Gold
 Body and contacts support materialPolycarbonate Bayer-2805
Mouting typeTo screw (hex screws)
Max conductor diameterØ8mm
Min/Max cable diameterØ6mm / Ø19mm
Voltage / Current250VAC 10A
Total dimensions77 x Ø40mm
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)10.0
5 reviews
Satisfait
Je n'arrive pas à savoir si cette prise a eu une incidence sur le son comme a pu l'avoir le câble secteur, mais j'ai ici une prise de qualité et facile à monter.
This review has been posted for VIBORG VF503G IEC C15 Connector Pure Copper Plated Silver / Gold 24k Ø19mm
Excelentes
Ao longo de muitos anos tenho usado e testado varias marcas de conectores, mas estas Viborg são as melhores, excente qualidade de construção, uma assinatura sónica neutra, com vozes e instrumentos mais reais e naturais, o espectro sonoro é comleto e sem esforço
... escelentes
This is the worst fitting connector I have ever used. I tried it on all of my IEC inlets in my system and the result was the same- poor and insecure plug-in connection, with lots of wobbling. This manufacturer should very carefully first examine the design of the plugs that come with any free AC cord before selling to customers.
A few hundreds sold so far and i'm afraid you're the only one with such issue ...
A bargain
Probably one of the top vfm IEC
Excellent
Même constat que pour la VF501G, donc commentaire identique. Elles sont différentes esthétiquement.
Celle-ci est plus jolie mais craint plus les micros rayures. Voilà pour les différences. Sinon c’est les mêmes techniquement et musicalement.
RQP imbattable
Patrick
The IEC C15 Viborg VF503G connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi...
