VIBORG VF508 IEC C7 Connector Copper Ø19mm
The Viborg VF508 IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper contacts for optimal conductivity. The robust body is made of nylon and fiberglass. The connector accepts cables up to 19mm in diameter with conductors up to 6mm. Mounting is simple with a screw-on system.
Reference : 16617
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
Viborg VF508
Viborg VF508 Connecteur IEC C7 Cuivre Ø19mm
Product typeIEC C7 Connector
Contacts materialPure copper
Body materialNylon / Fiberglass
Mounting typeTo screw
Compatible cable diameterØ6-19mm
Max conductors diameterØ6mm
Voltage / Current125V 7A
250V 2.5A
DimensionsØ33 x 73.5mm
Max cable diameter (mm)19.0
ConnecticFemale
ConnectorIEC C7
Rated current (A)2.5
Rated current (A)7.0
The Viborg VF508 IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal....
