IEC C7 Connector Silver Plated OFC Copper Ø19mm
The Viborg VF508S IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper contacts with double OFC copper and silver plating for optimal conductivity. Its robust body is made of nylon and fiberglass. The connector accepts cables up to 19mm in diameter with conductors up to 6mm. Mounting is simple with a screw-on system.
Product type | IEC C7 Connector |
Contacts material | Pure copper |
Plaquage contacts | OFC Copper Silver |
Body material | Nylon / Fiberglass |
Mounting type | To screw |
Compatible cable diameter | Ø6-19mm |
Max conductors diameter | Ø6mm |
Voltage / Current | 125V 7A 250V 2.5A |
Dimensions | Ø33 x 73.5mm |
Color | Black |
Max cable diameter (mm) | 19.0 |
Connectic | Female |
Connector | IEC C7 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Rated current (A) | 7.0 |
Rated current (A) | 2.5 |
