VIBORG VF512 Connector IEC C13 Pure Copper Plated Ø18mm
The VE512 serie power connectors are designed to for high quality power cables assembly.
They have a robust clamping system which ensures great stability from 6 to 18mm⌀ and are therefore quite suitable for HiFi cables with a large diameter.
Reference : 17498
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-04-2025.
VIBORG VE512
Connector IEC C13 Pure Copper Ø18mm
VIBORG VF512R Connector IEC C13 Pure Copper Silver / Rhodium Plated Ø18mm
A pure copper conductor (OFC Copper) ensures superior conductivity that will enhance the qualities of a well-built power-supply, benefiting all subsequent elements of the installation.
Finally, the assembly is protected by a lightweight aluminum housing with a elegant design. This material also limit any EMI / RFI interference that might impair the signal.
Connector TypeIEC C13
Contact materialsPure copper
Max cable diameter6-18mmØ
Plating contactsOFC copper
Max conductors dimensionsDiameter: 5.5mm
Section: 22mm²
AWG: 4
Voltage / Current125V AC/ 15A - 250V AC / 10A
Dimensions63.7x40mm / Length 81.5mm
ScrewScrews provided
ColorSilver
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Rated current (A)10.0
The VE512 serie power connectors are designed to for high quality power cables assembly. They have a robust clamping system which ensures great...
