VIBORG VF512S Mains Connector IEC C15 Copper Silver Plated Ø20mm
The Viborg VF512S IEC C15 power connector features superb build quality, using pure copper contacts with double OFC copper and silver plating, ensuring perfect electrical conductivity. The robust connector body is made of an aluminum alloy and a clear Bayer-2805 polycarbonate. The connector accepts cable diameters up to 20mm and conductors up to 8mm, enabling the design of high-quality power supply cables.
Reference : 16686
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 02-04-2025.
Viborg VF512S
Viborg VF512S Connecteur Secteur IEC C15 Cuivre Plaqué Argent Ø20mm
Product typeIEC C15 Mains connector
Contacts materialPur copper
Contacts platingOFC Copper
Silver
Body materialAluminum alloy
Bayer-2805 Polycarbonate
Max cable diameterØ20mm
Max conductor wires diameterØ8mm
Mounting typeTo screw
Voltage / Current125V 15A
250V 10A
DimensionsØ40 x 81.5mm
ColorSilver and transparent
Max cable diameter (mm)20.0
ConnecticFemale
ConnectorIEC C15
Rated current (A)10.0
Rated current (A)15.0
3 reviews
Qualité du produit
Très belle qualité de fabrication. Qualités sonores sur un Furutech S55N très satisfaisantes pour alimenter les équipements réseau.
This review has been posted for VIBORG VF512S Mains Connector IEC C15 Copper Silver Plated Ø20mm
Excelentes
Ao longo de muitos anos tenho usado e testado varias marcas de conectores, mas estas Viborg são as melhores, excente qualidade de construção, uma assinatura sónica neutra, com vozes e instrumentos mais reais e naturais, o espectro sonoro é comleto e sem esforço
... escelentes
 (3)
Robust and stylish connector
This connector is very robust with pretty nice buid quality and performs well even with a thicker cable. I have built a few cables with this connector together with 15917, 2059 and 3001. The connection terminals are robust enough to allow thicker cables to be used with secure connections.
These connectors are roomy enough to allow a led illumination being built in (at one's own risk), which looks particularly good with these connectors. I wish these could be a bit cheaper, although they are worth the price.
The Viborg VF512S IEC C15 power connector features superb build quality, using pure copper contacts with double OFC copper and silver plating,...
