VIBORG VF518R IEC C7 Connector Silver / Rhodium Plated Pure Copper Ø20mm
The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper contacts with triple OFC copper, silver and rhodium plating for optimal conductivity. Its robust body is made of nylon and fiberglass. The connector accepts cable diameters up to 20mm with conductors up to 6mm. Mounting is simple with a screw-on system.
Reference : 16624
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 23-04-2025.
Viborg VF518R
IEC C7 Connector Silver / Rhdoium Plated OFC Copper Ø20mm
Viborg VF518
The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper contacts with triple OFC copper, silver and rhodium plating for optimal conductivity. Its robust body is made of nylon and fiberglass. The connector accepts cable diameters up to 19mm with conductors up to 6mm. Mounting is simple with a screw-on system.
Product typeIEC C7 Connector
Contacts materialPure copper
Plaquage contactsOFC Copper
Silver
Rhodium
Mounting typeTo screw
Compatible cable diameterØ6-20mm
Max conductors diameterØ6mm
Voltage / Current125V 7A
250V 2.5A
DimensionsØ40 x 62.7mm
ColorSilver
Max cable diameter (mm)20.0
ConnecticFemale
ConnectorIEC C7
Rated current (A)7.0
Rated current (A)2.5
The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal....
