VIBORG VF523S Connector IEC C19 Silver Plated Pure Copper Ø19mm
This IEC C19 Viborg VF523S high-end connector uses high quality materials to provide the best possible electrical conductivity. Thus, the contacts are made of pure Copper and benefit from a double plating of OFC Copper and Silver. The body is made of a particularly resistant polycarbonate, Bayer Makrolon 2805. The assembly is extremely simple with a screw system, so no soldering is required. The connector accepts cables with a diameter from Ø6mm to Ø19mm and conductors with a maximum diameter of Ø8mm.
Reference : 15741
45,90 €tax incl.
38,25 € tax excl.
Viborg VF523S
Viborg VF523S Connecteur IEC C19 Cuivre Pur Plaqué Argent Ø19mm
Product typeIEC Connector
Connector typeIEC C19
Cable external diameterØ6mm - Ø19mm
Max. conductor diameterØ8mm
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Body materialBayer Makrolon 2805
Connection typeTo screw
Dimensions55 x 40mm
Total length75mm
Voltage / Current250V / 16A
125V / 20A
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C19
Rated current (A)20.0
Rated current (A)16.0
This IEC C19 Viborg VF523S high-end connector uses high quality materials to provide the best possible electrical conductivity. Thus, the contacts...
