VIBORG VI-06BC IEC C14 Connector Pure Copper Red Copper Ø6mm
With its VI-06BC, Viborg offers exceptional IEC connectors, thanks to a design using particularly high-end materials.
Reference : 12745
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 22-04-2025.
Viborg VI-06BC
IEC C14 Connector Pure Red Copper ⌀6mm
viborg VI-06BC embase iec c14 cuivre
Thus, the contact material of this connector is made of Pure Red Copper, which is not without attention. Indeed, copper is an excellent conductor, more efficient than gold. Moreover, the Copper used here is Red Copper, characterized by a "pink" hue, rather than classic Copper. The connector body will ensure good durability, using PBT and fiberglass. Viborg chooses a simple and practical installation with a cable fixing system using screws. No welding is required to mount the connecotr. In addition, each screw has a different colour, allowing quick identification of the different poles.
In short, these IEC C14 connectors are fully adapted to fit into a high-end HiFi audio system.
ConductorPure Red Copper (Purity : 99.995%)
Housing materialPBT and Fiberglass
Connection typeTo screw
Max cable diameter6mm
Dimensions51 x 24 x 35mm
Fixation holes spacing40mm
VoltageAC 250V 10A
Quantitu1
Max cable diameter (mm)6.0
Mounting typeTo screw
ConnecticMale
ConnectorIEC C14
Rated current (A)10.0
3 reviews
Viborg
Top class sound and better than my way more costly one from F-H
This review has been posted for VIBORG VI-06BC IEC C14 Connector Pure Copper Red Copper Ø6mm
Ce qu'il faut!!
Pour remplacer ce que l'on trouve sur nos appareils, même les chers, c'est ce qu'il faut!
Du cuivre pure, un boitier solide une fixation de câble sûr, il n'en faut pas plus pour avoir de la qualité.
Je recommande.
Couple IEC fiche et embase
Ces deux là, se marient à merveille, ( la fiche IEC et l'embase cuivre pur )
le câble secteur est constitué des fiches Schuko , IEC Viborg et du câble Viborg RISR 5N OFC Copper 6mm Litz Power Cord Wire
Je ne pensais pas que ces fiches et câble pouvaient améliorer la définition de mon système, je n'en reviens toujours pas, les musiciens sont là, dans mon salon, les timbres des instruments sont restitués à la perfection, l'image est des plus réaliste. Bravo pour cette prouesse pour un câble secteur qui revient à moins de 100€
