IEC C15 Connector Cryo Treatment Perma Lock Ø 16mm
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create high-performance power cables with IEC C15 connector. The Perma Lock design locks the screw threads so that they cannot move due to vibration or heat.
Practical connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering. A simple cross-head screwdriver is enough to fix your cables on the 3 contacts of the connector.
Intelligent design
The connector design maximizes the contact rate with a clamp and spring system for optimum conductivity. It also allows a firm and reliable fixing of the cables.
Strong cable handle
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This holds the cable securely in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Connector type | IEC C15 |
Max cable diameter | 16mm |
Acceptable cable section | 10 to 16AWG |
Current / Voltage | 10A / 250V AC 15A / 125V AC |
Body material | Nylon and polycarbonate |
Cryo treatment | Yes - DCT |
Connexion type | To screw |
Color | Black |
Dimensions | 72.7 x 38.1mm |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Girand Michel C.
