WATTGATE 350I AU IEC C15 Connector Triple Plating OFC Copper Nickel Gold 24k Cryo Treatment Ø16mm
WATTGATE 350I AU IEC C15 Connector Triple Plating OFC Copper Nickel Gold 24k Cryo Treatment Ø 16mm
The IEC Wattgate 350i AU connector is a resolutely high-end model with a very high design and design quality. This is an ideal model for anyone who wants to create performant power cables with IEC C15 connector and provide a system with a clean electrical signal for quality reproduction.
Reference : 13149
85,00 €tax incl.
70,83 € tax excl.
WATTGATE 350I Au
WATTGATE 350I Au Connecteur Schuko Triple Plaquage Cuivre OFC Nickel or 24k Traitement Cryo
Practical and efficient
wattgate 350i au iec c15
Convenient connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering. A simple cross-head screwdriver is enough to fix your cables on the 3 contacts of the connector.
Quality design
The connector contacts have triple plating. There is an OFC copper layer to obtain a very good conductivity, an electrolytic nickel intermediate layer to isolate the other two layers from each other and finally a last layer of gold 24k to further increase the resistance of the contacts to oxidation.
Wattgate 350i AG Connecteur IEC C15 Plaqué Argent
Effective cable clamp
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This firmly holds the cable in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
Cryo treated
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Wattgate 350i Au Connecteur IEC C15 Plaqué or
Connector typeIEC C15 connector
Contacts platingTriple plating :
  1. OFC Copper
  2. Electroless Nickel
  3. Gold 24k
Cable max diameter16mm
Acceptable cable section10 à 16AWG
Current / Voltage10A / 250V AC
15 A / 125V AC
Housing materialNylon and polycarbonate
Cryo treatmentYes - DCT
Connection typeTo screw
Dimensions8.3 x Ø 3.8cm
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
The IEC Wattgate 350i AU connector is a resolutely high-end model with a very high design and design quality. This is an ideal model for anyone who...
