ATAUDIO BLACK-AT Schuko Type E/F Power Connector Gold Plated Ø19mm
ATAudio's Black-AT Schuko connector features superb craftsmanship and will allow you to design high-end power supply cables that perform well. Its rugged metal shell conceals gold-plated contacts for excellent conductivity and durability,
Reference : 16973
23,90 €tax incl.
19,92 € tax excl.
ATAudio Black-AT
Power Connector Schuko Gold Plated Ø19mm
ATAudio Black-AT Connecteur d'Alimentation Schuko Plaqué Or Ø19mm
ATAudio's Black-AT Schuko connector features superb craftsmanship and will allow you to design high-end power supply cables that perform well. Its rugged metal shell conceals gold-plated contacts for excellent conductivity and durability, and a screw-in design for quick and easy assembly. The connector accepts large diameter cables from Ø15mm to Ø19mm.
Product typePower connector
ConnectorSchuko
Contacts platingOr
Shell materialMetal
Mounting typeTo screw
Min / Max cable diameterØ15mm / Ø19mm
Max cable diameter (mm)19.0
ConnecticMale
ConnectorSchuko
Rated current (A)N/A
Massive
Elle est massive pour le prix! Montage facile, cruciforme pour le corps, attention les autres vis (cosses et serrage du câble) sont avec une clef alen 2mm.
Diamètre du corps 38mm.
Respecter le diamètre 15 mini car les vis de serrage offrent peu de marge.
This review has been posted for ATAUDIO BLACK-AT Schuko Type E/F Power Connector Gold Plated Ø19mm
ATAudio's Black-AT Schuko connector features superb craftsmanship and will allow you to design high-end power supply cables that perform well....
