Excellente conception et construction.
Parfaite pour fabriquer des câbles d'alimentation de qualité. Nettement supérieure aux prises BALS qui coûtent près de 5 fois moins. Mais la différence à l'écoute est stupéfiante...
With their copper plated 24K gold contacts, connectors Schuko PS-24RA allow the construction of extremely effective power cables.
Designed to accommodate massive audio grade cables, adjustable retaining clip can work with all cable diameter from 5 to ⌀20mm.
The contacts are gold-plated screw. The bindings support the important conductors up ⌀4.5mm diameter.
The connector has an ideal angled design to ensure a clean and orderly cabling even in environments with limited space.
Likewise, the cradle of the connector can be mounted according to various axes and offers 9 positions through an angle of 300 °. So we may as well ride the final right connector, 90 or even on other angles (15 ° increments).
Type | Connector assembly |
connector | Schuko |
materials body | PC 94V-0 |
screw materials | 304 Stainless Steel |
contacts | Copper |
Plating | 24k |
cable compatibility | 5 - 20mm⌀ |
driver compatibility | Max 4.5mm⌀ |
body length | 73mm |
diameter body | 40mm⌀ |
Weight | 69g |
Max cable diameter (mm) | 20.0 |
Mounting type | To screw |
Connectic | Male |
Connector | PLug CEE 7/7 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | N/A |
Average votes 4.9 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
SERGE B.
Gerard B.
Cedric J.
Jean Paul G.
Jean Paul G.
