ELECAUDIO PS-24RA Schuko Type E/F Connector Angled Rotative Adjustable Red Copper Gold Plated Ø20mm
With their copper plated 24K gold contacts, connectors Schuko PS-24RA allow the construction of extremely effective power cables.
4.9 / 5
Reference : 13652
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 24-04-2025.
ELECAUDIO PS-24RA
Designed to accommodate massive audio grade cables, adjustable retaining clip can work with all cable diameter from 5 to ⌀20mm.
The contacts are gold-plated screw. The bindings support the important conductors up ⌀4.5mm diameter.
ELECAUDIO DIY Audiophile Connector for Power Cable Copper Red Copper
Shucko angled rotary connector audiophile DIY self-assembly
Angled and rotatable
The connector has an ideal angled design to ensure a clean and orderly cabling even in environments with limited space.
Likewise, the cradle of the connector can be mounted according to various axes and offers 9 positions through an angle of 300 °. So we may as well ride the final right connector, 90 or even on other angles (15 ° increments).
TypeConnector assembly
connectorSchuko
materials bodyPC 94V-0
screw materials304 Stainless Steel
contactsCopper
Plating24k
cable compatibility5 - 20mm⌀
driver compatibilityMax 4.5mm⌀
body length73mm
diameter body40mm⌀
Weight69g
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)N/A
13 reviews
Perfect!
Produit conforme à la description, livraison rapide et sûre. Merci pour une transaction réussie!
This review has been posted for ELECAUDIO PS-24RA Schuko Type E/F Connector Angled Rotative Adjustable Red Copper Gold Plated Ø20mm
Excellente prise schuko coudée
Excellente conception et construction.
Parfaite pour fabriquer des câbles d'alimentation de qualité. Nettement supérieure aux prises BALS qui coûtent près de 5 fois moins. Mais la différence à l'écoute est stupéfiante...
Très bonne prise
Très content ,très bien finie, je la recommande , mais je ne peux pas juger l’amélioration audio car je l'ai utilisée pour alimenter un filtre secteur de ma fabrication .donc le montage terminé je n'ai plus comparé avec une fiche normale.
Pratique
Comme son jumeau en iec, ce connecteur est super pratique pour les câble de grosse section et pour gagner de la place sans abîmer le matos. Bonne restitution .
Excellent
Prise qui Apporte un plus dans tous les registres, neutre et transparent, ne changeant pas les caractéristiques de votre ampli, cd.. c’est étonnant en enlevant, et en remettant une prise lambda avec un câble normal …magnifie un câble plus haut de gamme..
coude.. plus petit? Serais mieux mais garder la même qualité sonore, recommandé
RQP? AAA+
