- We deliver this connector without marking, the small Elecaudio sticker visible on the pictures is not delivered -
The reference Schuko plug PS-34GCis distinguished at first glance by its transparent nylon bodywith impeccable finishing and ideal proportions.
With a black screenprint in the brand's colors, this chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
With herInsertion ring to limit diameter to 16.5mm , with a greenhouse flexible rubber cable perfecting the integration, the PS-34GC easily hosts cables of large cross-section.
All metal parts, including the contact and ground poles, have benefited from a plating "Direct Gold"(without nickel undercoat) Gold5μ .
This plating present over the entire surface of the contacts provides a better conductivity compared to a standard plating .
The internal connection terminals also deserve attention: They are equipped with large fastening screws and therefore do not require any welding, they are able to receive large diameter conductors which hold firmly on a surface of particularly wide contact.
Finally,small diagram directly engraved within the socket, and which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left to chance ...
Specifications:
- Schuko plugs 3 Screw-in contacts (BTR screws 2mm)
- Plating:Gold 24k 5μ
- Maximum Driver Section:16mm²(4.5mm of Diameter)
- Maximum Cable Diameter: 16.5mm
- Voltage / Voltage Rating: 16A / 250V
- Overall Length: 89 mm
- Diameter: 38 mm
Cable schematics
