ELECAUDIO PS-34SB Socket Schuko Black Silver Ø16.5mm
Reference : 8100
24,90 €tax incl.
20,75 € tax excl.
- We deliver this connector without marking, the small Elecaudio sticker visible on the pictures is not delivered -
The reference Schuko plug PS-34SBis distinguished at first glance by its black anthracite nylon bodywith impeccable finishing and ideal proportions.
With a black screenprint in the brand's colors, this chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
With herInsertion ring to limit diameter to 16.5mm , with a greenhouse flexible rubber cable perfecting the integration, the PS-34SB easily hosts cables of large cross-section.
All metal parts, including the contact and ground poles, have benefited from a plating "Direct Silver"(without nickel undercoat).
The internal connection terminals also deserve attention: They are equipped with large fastening screws and therefore do not require any welding, they are able to receive large diameter conductors which hold firmly on a surface of particularly wide contact.
Finally, we will appreciate the small diagram directly engraved within the socket, which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left behindrandomly...
Specifications:
  • Schuko plugs 3 Screw-in contacts (BTR screws)
  • Plating:Money
  • Maximum Driver Section:16mm²(4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 89 mm
  • Diameter: 38 mm
https://www.audiophonics.fr/images2/8100/8100_elecaudio_PS-34SB_thumbs.png
https://www.audiophonics.fr/images2/8100/8100_elecaudio_PS-34SB_1.jpg
https://www.audiophonics.fr/images2/8100/8100_elecaudio_PS-34SB_2.jpg
https://www.audiophonics.fr/images2/8100/8100_elecaudio_PS-34SB_3.jpg
https://www.audiophonics.fr/images2/8100/8100_elecaudio_PS-34SB_4.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Cable schematics
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
2 reviews
Bravo
Suite à mon dernier commentaire, j'ai reçu les autocollants sans avoir réclamé.
Bravo Audiophonics pour l'après vente !
Mais aussi vous lisez nos commentaires et en tenez compte !
This review has been posted for ELECAUDIO PS-34SB Socket Schuko Black Silver Ø16.5mm
Prise reçu et de bonne qualité. Suffisant pour les petits appareil.
Par contre, pas d'autocollant fourni...comme il est écrit plus haut. J'aurais bien aimé plus le coté esthétique.
Idem pour le petit schéma d'aide au montage, il n'y a rien, mais je n'en ai pas besoin.
