ELECAUDIO PS-34SC Socket Schuko Crystal Silver Ø16.5mm
Reference : 8099
24,90 €tax incl.
20,75 € tax excl.
- We deliver this connector without marking, the small Elecaudio sticker visible on the pictures is not delivered -
The reference Schuko plug PS-34SC is distinguished at first glance by its transparent nylon bodywith impeccable finishing and ideal proportions.
With a black screenprint in the brand's colors, this chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
With herInsertion ring to limit diameter to 16.5mm , with a greenhouse flexible rubber cable completing the integration, the PS-34SC easily accommodates cables of large cross-section.
All metal parts, including the contact and ground poles, have benefited from a plating "Direct Silver"(without nickel undercoat).
The internal connection terminals also deserve attention: They are equipped with large fastening screws and therefore do not require any welding, they are able to receive large diameter conductors which hold firmly on a surface of particularly wide contact.
Finally, we will appreciate the small diagram directly engraved within the socket, which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left behindrandomly...
Specifications:
  • Schuko plugs 3 Screw-in contacts (BTR screws 2mm)
  • Plating:Money
  • Maximum Driver Section:16mm²(4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 89 mm
  • Diameter: 38 mm
https://www.audiophonics.fr/images2/8099/8099_elecaudio_PS-34SC_thumbs.png
https://www.audiophonics.fr/images2/8099/8099_elecaudio_PS-34SC_3.jpg
https://www.audiophonics.fr/images2/8099/8099_elecaudio_PS-34SC_2.jpg
https://www.audiophonics.fr/images2/8099/8099_elecaudio_PS-34SC_1.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
scHéma de Wiring
ColorTransparent
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorType E (CEE 7/5 - CEE 7/6)
Produit d'excellente qualité, facile à utiliser pour un non spécialiste.
This review has been posted for ELECAUDIO PS-34SC Socket Schuko Crystal Silver Ø16.5mm
