ELECAUDIO RS-24GB Schuko Power Plug Fiber Glass 24k Gold Plated
4.9 / 5
Reference : 10024
24,90 €tax incl.
20,75 € tax excl.
ELECAUDIO RS-24GB
These Hi-Fi connectors have been developed in France to be used with the most sophisticated cables there are.
The body has a modern and exclusive design, which is now molded under high pressure.
Made of 30% fiberglass and 66% Nylon it can withstand industrial-level constraints. (High temperature, crushing, scratches).
Because of this, the RS24GB connector can be seen as a hybrid model which offers industrial quality for Hi-Fi requierements.
Conjugated with a thickness of 4mm this material has a tremendous rigidity and resistance to vibrations and resonances.
Each connectors is held by a stainless steel screw for maximum strength.
The head connector also benefits the alloy Fiberglass / Nylon for its dielectric and mechanical properties.
Contacts are made of copper alloy nonmagnetic in one piece and cut in the mass, on which is applied a 24K gold plating
The input diameter contacts enables compatibility with all cables market sectors. (15mm²)
Right Cable mount
Materials30% glass fiber and 66% Nylon
Electric contactsScrew (Vis BTR 2mm)
Plating24k Gold
Conductor section max15mm² (4.5mm diameter)
Cable diameter13.5mm to 16.5mm
Intensité / Voltage16A / 250V
Total length103.7 mm
Diameter42 mm
Weight92 g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
8 reviews
une des meilleures
Une restitution d 'un grand naturel avec des détails mais transmis de façon homogéne . Scéne sonore épannouie .Connectée à un cable yarbo cuivre argent sur ce même site . Je la préfére à la viborg or /argent sur le même type de cable . une écoute sans fatigue proche de la réalité.
This review has been posted for ELECAUDIO RS-24GB Schuko Power Plug Fiber Glass 24k Gold Plated
Good one!
Very good in Quality and handling. In the meantime i´ve build three powercables with the RS-24GB and would also use it for further Powercables :)
Good one!
worth it´s price
tres bon produit
livraison rapide , colis solide , état impeccable !
cette prise est de bonne qualité avec un diamètre de câble impressionnant ! facile à monter ; à condition de trouver la bonne clé ! j'ai du utiliser une clef six pans pour poignées de portes !
Mais le plus important c'est l'apport niveau musique ! elle remplace une prise de bas de gamme sur un bryston 4 b ! l'apport est super en dynamique attaques de notes ,transitoires , maitrise des basses etc !!
une très bonne idée !
Bien
Bonne qualité dans l'ensemble : la bague de serrage du cable (arrière de la prise) est prévu pour un diamètre de cable déjà conséquent, un adaptateur pour des cables de plus faible diamètre aurait été bien vu. Il faut penser à bien insérer le tournevis six plans a fond dans les vis de serrage pour ne pas endommager les dites vis. Bon résultat à ce niveau de prix.
