These Hi-Fi connectors have been developed in France to be used with the most sophisticated cables.
The body has a modern and exclusive design, which is now molded under high pressure.
Compound 30% fiberglass and 66% Nylon it can withstand industrial constraints. (High temperature, crushing, scratches).
We could consider this connector as a hybrid, an industrial grade adapted to the requirements of Hi-Fi use.
Conjugated with a thickness of 4mm this material offers it a rigidity and a resistance to the vibrations and resonances very important.
Tightening of the cable is now carried out with a rotating ring which adapts to a diameter from 13.5 to 16.5mm . (diameter reducer available in the accessories below)
The advantage of this ring in addition to a very effective tightening is that the cable remains centered and aligned whatever its diameter.
All of thescrewof the connectors areStainless Steel Blackfor maximum strength.
The connector head also benefits from the Fiberglass / Nylon alloy for its dielectric and mechanical qualities.
On the series of connectors "34"ELECAUDIO ato propose the best possible conductivity replacing the nickel undercoat with a layer of nickel, ATrgentof high thickness.
To avoid oxidation a veneer 24K Goldof finishing there is then applied./ P>
The input diameter of the contacts allows compatibility with all the cables sector of the market. ( 15mm² )
Features:/ Strong>
- Body: 30% Glass Fiber and 66% Nylon
- Screw-in contacts (BTR screws 2mm)
- Plating:Silver / Gold 24k
- Maximum Driver Section:15mm²(4.5mm of Diameter)
- Cable Diameter: from 13.5mm to 16.5mm
- Voltage / Voltage Rating: 16A / 250V
- Overall Length: 103.7 mm
- Diameter: 42 mm
- Weight: 92g
