FURUTECH FI-E11 (Cu) Schuko Type E/F Power Connector Copper Ø20mm
4.6 / 5
Reference : 2169
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 29-11-2024.
This is a Furutech FI-E11 (Cu) plug ideal for the creation of high-end power cords with exceptional performance. Furutech's reputation and fame is well established as their products have outstanding qualities and advantages.
Features:
  • Conductors: Copper alloy treated with the "Furutech Alpha α" anti-magnetism process
  • Insulation: Nylon / Fiberglass
  • Housing: Polycarbonate
  • Compatible with French socket and Shucko
  • This connector fits an external cable diameter from 6.6mm up to 18mm (with longer screws up to 20mm)
  • 250V / 16A
  • Dimensions:
  • Diameter: 39mm
  • Body Length: 56mm
  • Overall Length: 88mm
ColorTransparent
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
11 reviews
Assez bien
Le connecteur est indéniablement de bonne qualité, mais à une tendance à comprimer un peu la dynamique et la définition : "trop sage". Utilisé sur un ampli audio résultat moyen, mais très bon sur un AVR de moyenne gamme de qualité (lisse peut être les défauts de ces appareils en audio).
This review has been posted for FURUTECH FI-E11 (Cu) Schuko Type E/F Power Connector Copper Ø20mm
Great choice for high-current applications, it seems
I use a Furutech eTP66EG power strip. However, my wall socket is very much pedestrian. I have beeen looking to upgrade the plugs on my Vovox initio power cord (silver-plated solid core copper) that feeds the Furutech strip for some time now, trying all kinds of different plugs. Now, I've found my solution: FI-E11 (Cu) as Schuko and FI-11 (Cu) as IEC. It provides superior dynamics, more authority, weight and slam than e.g. the Furutech FI-E11 Gold oder the Viborg VE501 pure copper.
For some resaon, using the FI-E11 (CU) in the power strip, supplying power to individual components, doesn't work quite as well for me. There it tends to sound a bit tired, with somewhat subdued treble. It lacks refinement. But for the power strip, where the plug has to deliver a lot of wattage and current, it seems ideal to me.
Bonne prise
Accepte du gros cable, raison de mon choix, mais faut se battre un peu au moment du serrage du cable surtout si on a ajoute de la gaine acrylique+ thermo comme moi. Tres silencieuse, avec la connection du blindage flottant sur la terre coté male. J'en ai pas essayé d'atre mais j'en suis très content, rapport QP excellent pour moi
bon produit furutech
rien à dire sur les prise schuko furutech FI-E11 CU vraiment bien pas regret à recommander sans modération merci
Pour avoir comparé les connecteurs schuko furutech cuivre à des oyaides ( pas des copie chinoises ) sa me semble pas comparable et assez idiot de passé d une oyaide a presque 200 euro a une schuko cuivre a 32 euro ces sur quon trouvera que des avantages a la plus onéreuse en géneral, comparons ce qui et comparable tout le monde a pas 200 roro a mettre sur une schuko ,a 32 euro cette tete schuko et de loin excellente ,moi je conseil cette tete schuko ou yarbo qui et amplement suffisante. Si vous voulez de la dynamique associé le avec le furutech 3ts20 cable secteur le plus rapide que j ai pu ecouter ou avec un modulation TBB 100 DNM une rapidité et neutralité hors du commun.
 (5)
