FURUTECH FI-E12L (G) Schuko Type E/F Power Connector 90° Angled Adjustable Gold Plated Pure Copper Ø18mm
The Furutech FI-E12L (G) is a 90° angled Schuko connector incorporating high-quality materials for creating high-end power cables. Pure Copper contacts with gold plating promote both conductivity and durability of the connector. The connector has a diameter that allows it to accept cables from 6.6mm to 18mm in diameter.
Reference : 13296
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 07-01-2025.
Connecteur Schuko Coudé 90° Ajustable Cuivre Pur Plaqué Or Traitement Alpha
Furutech FI-E12L (G) Connecteur Schuko Coudé 90° Ajustable Cuivre Pur Plaqué Or Traitement Alpha
The Furutech FI-E12L (G) is a 90° angled Schuko connector incorporating high-quality materials for creating high-end power cables. Gold plated Pure Copper contacts increase both conductivity and durability of the connector. The connector has a diameter that allows it to accept cables from 6.6mm to 18mm in diameter.
In addition, each connector receives a α (Alpha) treatment consisting first of cryogenization at -250°C to consolidate the molecular structure of the conductors and then demagnetization. The conductivity of contacts is greatly improved and they are less sensitive to disturbances from the environment. Furutech also incorporates Floating Field Damper System technology into these connectors to eliminate any floating magnetic fields that could create noise and therefore distortion.
The connector body is made of Nylon and Glass Fiber as well as Carbon particles to absorb vibrations and resonances. The cable is fixed by an efficient clamping system that reduces distortion induced by mechanical and electrical actions..
Finally, the connector incorporates a convenient feature: the connector can rotate 90°, 180° or 270° to fit your power outlet and facilitate connections.
Product type90° Angled and adjustable Schuko Connector
Contacts materialPure copper
PlatingGold
Treatment / TechnologyAlpha treatment
Acceptable cable diameterFrom 6.6 to 18mm
Body materialNylon
Glassfiber
Carbon particles
Body material44 x 42.2 x 55mm
Overall dimensions84 x 42.2 x 55mm
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)N/A
4 reviews
Excellente fiche secteur
Produit excellent s'adapte à différentes inclinaisons surtout lorsque le câble est gros et ne se courbe pas trop facilement: il est bien rangé ainsi grâce à cette disposition. Juste trouvé la vis manquante qui retient la liaison terre schuko. Ne m'en suis pas aperçu tout de suite, mais un jour d'orage violent, en débranchant mes équipements, les broches de terre sont restées dans la prise. J'avais heureusement de la visserie compatible et j'ai pallié le défaut sans avertir le SAV. Il y avait trop de d'écart entre ma commande et le jour où je m'en suis rendu compte. Donc excellent produit, mais lorsque vous le recevrez vérifiez bien que la petite vis est présente pour le signaler dès réception à Audiophonics. Je donne 5 étoiles au produit, sachant que dans les cartons de production et d'emballage ce type de vis peut facilement s'égarer si elle n'a pas été suffisamment serrée par le fabricant.
This review has been posted for FURUTECH FI-E12L (G) Schuko Type E/F Power Connector 90° Angled Adjustable Gold Plated Pure Copper Ø18mm
Excellent Connecteur
Ce connecteur de marque Furutech est un excellent produit. Le poids de celui-ci, même si cela ne fait pas tout, montre bien que l'on est en présence d'un produit de qualité. Le montage du câble ne pose pas de problème, même si des câbles de bon diamètre et blindés sont pas faciles à positionnées dans le coude. Le dispositif de serrage des câbles est très qualitatif et très efficace. Le fait de pouvoir orienter la sortie sur plusieurs positions est un plus. Le prix peut paraître élevé, mais pour connecter des câbles de qualité supérieure, cela est justifié.
parfait
Produit d'excellente facture, comme les connecteurs IEC de la même gamme.Le serrage des contacts sont efficaces et acceptent de gros diamètres.Toujours satisfait des produit furutech, certes un peu chers mais durables (le poids en dit long).Livraison rapide comme d'habitude.
Parfait
Fiche d'excellente facture comme les fiches IEC de la même gamme.
J'ai hésité en raison du prix mais la qualité est indéniable. Le corps de la fiche est en métal, pèse lourd, et respire la qualité.Le serrage (en "étau") des contacts est très efficace et accepte des câbles de grosse section.
Je n'ai jamais été déçu par les connecteurs Furutech, même d'entrée de gamme.
The Furutech FI-E12L (G) is a 90° angled Schuko connector incorporating high-quality materials for creating high-end power cables. Pure...
