FURUTECH FI-E38 (R) Schuko Type E/F Power Connector Rhodium Plated Ø17.5mm
4.7 / 5
By buying this product you get 42 loyalty points
Reference : 4754
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
Schuko mains plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its contacts Copper plated Rhodium, the FI-E38 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α, which involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FI-E38 also takes advantage of the patented technology "Floating Field Damper System"which makes it possible to eliminate almost totally the creation of micro-magnetic and electrostatic turbulence zones internally of the plug, perturbations generated by the passage of the current in proximity(fixing screws of metal, clamping elements of the cable, etc.). These "floating" field micro-fields conflict with the much more powerful primary magnetic flux generated by the current flow through the cable and the connectors, thereby inducing a form of electrical resistance detrimental to conductivity, generate a form of distortion. FURUTECH succeeds in controlling these phenomena by connecting all the metallic parts concerned together with a conductor charged with bringing all these undesirable energies to the earth.
Its body in material compositenylon and fiberglassinjected from carbon particlesit demonstrates extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fixed by means of3 screws (2 poles + ground) marked with color code and whose firmness of maintenance, obtained thanks to the technology FURUTECH "Wire Clamp", makes it possible to exclude any risk of tearing or accidental deterioration of the cable, while significantly improving the contact surface.
Compatible with cables in the section is included between 6 and 17.5mm in diameter.
Features:
  • contactsCopper Pure Rhodium Plated
  • Anti-Magnetism
    FURUTECH Alpha α
  • Technology Owner "Floating Field Damper System"
  • Nylon Body & Fiberglass Injected Carbon Particle
  • Screw plug (3 screws marked with color code)
  • Patented "Wire Clamp" Cable Tightening Technology (Improved Contact Area of ​​17%)
  • Compatible with Cables of Diameter between 6 and 17.5mm
  • Body Length: 90.5mm
  • Body Diameter: 39.6mm
  • 250V / 10A - 125V 15A
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_6.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28R_3.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_1.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_4.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_5.jpg
center ">https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_3.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_2.jpg
Max cable diameter (mm)17.5
Mounting typeTo weld
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)15.0
7 reviews
Good
Sound is great, incisive yet well balanced and with natural timbre. It's punchy and dynamic too.
The only reason I'm taking a star from it is that plastic build and parts fit could be better for this price. Viborg has much better build for one third of the price, but can't compre sonically to this Furutech.
This review has been posted for FURUTECH FI-E38 (R) Schuko Type E/F Power Connector Rhodium Plated Ø17.5mm
belle neutralité et vigeur!
Bonsoir , j ai remplacé ma fi38 or par la rhodium sur ma murale oyaide , la rhodium est plus transparente ,neutre ,rapide,precise, et l or un peu plus chaleureuse ,ronde . Pour un systeme sombre ou lourd optez pour la rhodium ,pour un systeme deja clair ou maigre optez pour l or , La fi38 rhodium est la meilleure schuko que j ai testé a ce jour !
 (3)
la neutralité !!!!!!!!!!!!!
Bonsoir ,j ai comparé avec la version gold , la rhodium est plus transparent,neutre, rapide, precis, detaillé, juste un peu moins chaud et moins rond , qualté prix une des meilleurs schuko du marché!! Franck
Gain très appréciable sur la réalité de l’image sonore, la qualité des silences, la richesse des timbres et des textures... Grande pureté des voix, intelligibilité accrue... tout ça par rapport à la version Gold, la FI 38, Déjà , elle sur une embase FIE30 NCF Rhodium. Le gap franchi est il dû au rhodium seul, ou au contact entre embase et connecteur maintenant homogène tout rhodium? En tout cas, pour l’instant, l’apport sur mon câble ampli, avec une IEC FI 11 gold est déjà grand, et milite pour le changement futur de l.IEC... un réel investissement, c’est vrai, mais quel gap!
fabuleux vraiment top
Le furutech Fi-E38-R est fabuleux par contre la référence furutech FI-E48-R gagne beaucoup plus avec piezo céramic carbone à l'intérieure du boitier une rapidité énorme bruit fond super bien présenté juste le prix c'est un choix personnel de votre système la plus haute gamme chez furutech NCF le rêve extraordinaire magnifique ko merci .
