FURUTECH FI-E46 NCF (G) Schuko Type E/F Power Gold Plated Copper Alpha Treatment NCF Ø20mm
The Furutech FI-E46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use.
Reference : 13890
239,00 €tax incl.
199,17 € tax excl.
Shipping date: 18-12-2024.
Gold Plated Copper SchukoConnector Alpha Treatment NCF
Furutech FI-E46 NCF (G) Connecteur Schuko Cuivre Plaqué Or Traitement Alpha NCF
The Furutech FI-E46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use. The connector contacts are made of pure gold-plated copper with Alpha treatment (α). The latter consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect. The connector shell is made of anodized and brushed aluminum, improving both the durability of the connector and limiting the impact of interference on the signal. The connector also uses an efficient cable holding system, using a metal clamp.
Floating Field Damper System
The magnetic field running through a cable and its connector create a magnetic and electrostatic field around them several times a second. This magnetic field induces current leakage and electrical potential in small components such as screws that hold the connector body and must be made of metal for effective clamping. Current leaks in these components create a magnetic field floating around them and interfering with the larger magnetic field of the cable and connector and generating distortion and noise.
The Floating Field Damper System solves this problem by grounding these metal parts. All the different metal parts of the connector are connected to each other and shunt the generated electrical potentials to ground. This significantly reduces noise by reducing distortion for extremely clean and stable energy transfer.
Product typeSchuko Connector
Contacts materialPure Copper, Alpha Treatment (α)
Contacts platingGold
Insulation technologyFloating Field Damper System
Connector body materialsNylon / Fiberglass and NCF
Damping materialCeramic nanoparticles and carbon powder for piezoelectric damping
Connector shell materialAnodized and brushed Aluminium
Min / Max Cable diameterMin : 6mm
Max : 20mm
Connector dimensionsBody : 55.4 x Ø39.5mm
Total length: 93.2mm
Cable tightening systemMetal clamps
Weight130g
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)N/A
5 reviews
Rien a redire
Je suis passé de la FI-E12L (G) à la FI-e46 (g), il y a bien une différence...c'est plus aérien, plus précis, plus fin, et sans agressivité
J'étais septique et le prix laisse à réfléchir, mais je ne regrette pas, après avoir essayé la p004 d'oyaide (pas mal mais fatigante), je suis conquis, et le plaisir d'écouter de la musique acru.
This review has been posted for FURUTECH FI-E46 NCF (G) Schuko Type E/F Power Gold Plated Copper Alpha Treatment NCF Ø20mm
Une loupe pleine de douceur
Monté en remplacement d'une fi 34 gold sur un câble furutech 32, et après une bonne vingtaine d'heures de rodage (obligatoire sinon attention les oreilles) le gap est significatif, les aigus sont légèrement plus présents tout en restant soieux, j'ai aussi gagné en présence. Je suis satisfait de mon achat.
Silence a bord!
Bonjour ,fi46 or ncf associée a un tunami V2 oyaide et iec charlin sur mon nuprime ida8,apres 30h rodage ( je pense 200 h minimum ) la fi46 ncf un sonoritée legerement chaude ,analogique , avec un silence tres tres poussé , bruit de fond tres precis, bonne dynamique , basse equilibrée , ma meilleure schuko a ce jour ( j image la fi50 encore meilleure ) le ncf est vraiment au dessus des autres ! franck
super la classe
Furutech NCF est vraiment super rien à dire avec des câble secteur haute gamme la déférence est flagrant franchement merveilleux un son reposant pas fatigue à la fin on respire enfin merci !
super produit
la gamme furutech cuivre NCF est vraiment top mais en version rhodium est supérieure ça dépend de votre système audio vidéo super top furutech NCF news année 2019
The Furutech FI-E46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech...
