FURUTECH FI-E50 NCF (R) Schuko Type E/F Power Connector Rhodium Plated Carbon Ø20mm
By buying this product you get 126 loyalty points
Reference : 11106
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 23-04-2025.
Here is the high-end Schuko power connectors, for the realization of high-end audio cable audiophile.
This new version, known as NCF (Nano Crystal Formula), incorporates an active material in the insulating body which generates negative ions which eliminate static discharges by converting them into thermal energy in the infrared spectrum.
Furutech combines this crystalline material with ceramic particles and carbon powder with electric Piezo damping properties.
Thea conjugation with the Nano Formula Crystal and the piezo ceramic particles provides the ultimate electrical outlet, the long culmination of Furutech's know-how in this field.
NCF technology:
Incorporated in the new series of Furutech products, the NCF (Nano Crystal² Formula) consists of a special crystalline material that has two "active" properties.
TFirst, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) whose wavelength varies from (50 μm to 5 mm).
Furutech combine then this remarkable material with nanometric ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electric and mechanical damping material - (only available in Furutech products!).
Features:/ Strong>
  • Conductors: Pure Plated copper Rhodium "Furutech Alpha α"
  • Insulation: Nylon / fiberglass.
  • Case: Nylon / fiberglass nano ceramic particles for absorption of vibrations and resonances.
  • Multi-layer non-magnetic stainless steel and carbon fiber.
  • NFC: Addition of antistatic nano crystalline particles in the carbon ceramic body.
  • Compatible with French base.
  • This connector adapts to an external cable diameter of 6mm up to 20mm.
  • 250V / 16A.
Dimensions:
  • Diameter: 39.5mm.
  • Body Length: 44mm
  • Overall Length: 93.2mm
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
4 reviews
Exceptionnelle
La série 50 est vraiment un cran au dessus de la série 48. Encore plus d'aération, plus de contrôle, de maîtrise, scène sonore plus précise!
Utilisée avec une IEC 50 sur un câble secteur Furutech 055N, l'effet est impressionnant sur l'appareil électronique sur lequel ce câble secteur est installé!
Cher certes mais efficace!!
This review has been posted for FURUTECH FI-E50 NCF (R) Schuko Type E/F Power Connector Rhodium Plated Carbon Ø20mm
Fiche au TOP !
Associé au câble TCS31 de Furutech, le mariage est TOP (voir mon avis sur le TCS31) . Robuste, de grande qualité. Montage aisé.
vraiment génial
le furutech FI-E48-R est déjà sublime rien à dire par contre la gamme furutech NCF passe le niveaux classe mondial exceptionnel un rare moment à écouté urgent avec des câbles secteur haute gamme furutech franchement bravo chapot il y à pas mieux merci .
vraiment fabuleux
prise secteur furutech NCF franchement les meilleurs article du moment exceptionnel malgré sont prix sur les câble secteurs haut gamme la grande classe un pur bonheur année 2017 merci .
