This Neotech NC-P312G MKII Schuko connector will enable you to design your own high-performance sector cables. It incorporates G-UPOCC composite contacts, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Furthermore, to guarantee perfect conductivity while offering flawless protection against corrosion and oxidation, the NC-P312G MKII contacts are double-plated, first in silver, then in gold. Finally, this connector has been cryogenically treated, further improving its conductivity.
Product type | Schuko connector |
Contacts material | G-UPOCC Copper |
Contacts plating | Silver Gold |
Max cable diameter | Ø24mm |
Diameter with reducers | Ø11mm Ø14mm Ø17mm Ø24mm |
Max conductor section | 5.5mm² |
Cryogenic treatment | Yes |
Dimensions | Ø42 x 79mm |
Package | Sold by unit |
Max cable diameter (mm) | 24.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Schuko |
Contacts Material (Connector) | Graphene |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Contacts Plating (Connector) | Gold |
Rated current (A) | N/A |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
