NEOTECH NC-P312G Schuko Type E/F Power Connector Gold Plated UP-OCC Copper Ø20mm
This Schuko Neotech NC-P312G connector will allow you to design your own high-performance power cables. It features 99.99999% pure UP-OCC copper contacts with 24K gold plating, ensuring optimal conductivity and resistance to oxidation.
Reference : 14661
79,00 €tax incl.
65,83 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Neotech NC-P312G
Schuko Connector UP-OCC Copper Gold Plated Ø20mm
Neotech NC-P312G Connecteur Schuko Cuivre UP-OCC Plaqué Or 24K Ø20mm
This Schuko Neotech NC-P312G connector will allow you to design your own high-performance power cables. It features 99.99999% pure UP-OCC copper contacts with 24K gold plating, ensuring optimal conductivity and resistance to oxidation. Assembly is simply done via a screw system, without the need for soldering. The connector is delivered with reducers to effectively hold your cable.
Product typeSchuko connector
Contacts materialUP-OCC Copper
Contacts platingGold 24K
Max cable diameterØ20mm
Diameter with reducersØ18mm
Ø16mm
Ø14mm
Ø12.8mm
Max conductor section3.31mm² (12AWG)
Mounting typeTo screw
Total dimensionsØ40.5 x 79mm
Max cable diameter (mm)20.0
ConnecticMale
ConnectorSchuko
Rated current (A)N/A
Prise neotech
Pour moi, la meilleure prise que j ai eu..tient bien dans la barrette. Par contre le vissage du câble dans les trous, il faut faire très attention...surtout si c est un câble assez fin. Neotech devrait fournir un contre serrage du conducteur...ils peuvent m'en envoyer un si il y avait un ajout ultérieur.
This review has been posted for NEOTECH NC-P312G Schuko Type E/F Power Connector Gold Plated UP-OCC Copper Ø20mm
This Schuko Neotech NC-P312G connector will allow you to design your own high-performance power cables. It features 99.99999% pure UP-OCC copper...
