RAMM AUDIO SCHUKO-01 Power Connector Schuko Type E/F 24K 3µ Gold Plated Ø16.5mm Transparent
The Schuko-01 power connector from Ramm Audio is an E/F type power connector with a high-quality, transparent nylon body. Aesthetically pleasing and highly robust, this chassis is perfectly adapted to the integration of sophisticated, high-end cables, and its proportions make it the ideal ally for large-diameter cables and conductors.
Reference : 17859
44,90 €tax incl.
37,42 € tax excl.
RAMM AUDIO Schuko-01
RAMM AUDIO SCHUKO-01 Connecteur Secteur Schuko Type E/F Plaqué Or 24K Ø16.5mm Transparent
This connector accepts cable diameters up to Ø16.5mm. Thanks to a rubber cable clamp, your large cross-section cables will be securely held in place. The contacts are cryogenically treated to make them more resistant over time, and feature 3µ thick 24k gold plating for maximum conductivity and resistance to oxidation and corrosion.
Finally, the internal connection terminals feature large screws and a particularly large contact surface. No soldering is required to integrate your cable, and large-diameter conductors are firmly held in place.
Product typeSchuko E/F Type power connector
Connection typeTo screw
Maximum cable diameterØ16.5mm
Maximum conductor section16mm² (Ø4.5mm diameter)
TreatmentCryogenic
Contacts plating24k 3µ Gold
Voltage / Current250V 16A
DimensionsØ38mm*89mm
Weight80g
ColorTransparent
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorType F (CEE 7/3 - CEE 7/4)
ConnectorSchuko
ConnectorType E (CEE 7/5 - CEE 7/6)
ConnectorPLug CEE 7/7
Rated current (A)16.0
The Schuko-01 power connector from Ramm Audio is an E/F type power connector with a high-quality, transparent nylon body. Aesthetically pleasing...
