Schuko Type E/F Power Connector Mennekes 230V Ø15mm
4.7 / 5
Reference : 931
11,50 €tax incl.
9,58 € tax excl.
Shipping date: 06-05-2025.
Power connectors are located on hot surfaces, especially when they do not meet a high standard.
Among the Mennekes SCHUKO and CEE 230/400 V connectors, we have made a judicious choice of "made in Germany" products with excellent electrical and mechanical characteristics.
Users of these connectors must be in possession of sound electrotechnical knowledge. The circuit must only be switched on when a fault current circuit-breaker is integrated between the power supply and the consumer.
The CEE connectors comply with ICE309-1 / -2, DIN EN60309-1 / -2, DIN VDE0263 and protection class IP44. The SCHUKO connectors comply with DIN49440-1 / -2 / -3 and VDE 0620. The appropriate ATRIUM FLEX, SILCOFLEX and RUBBERFLEX cables can be found in this catalog under " Cables per meter ".
SCHUKO cable plug male, black, high-strength with anti-crease sleeve, 230 V / 16 A
Max. Cable sheath diameter: 15mm
Max cable diameter (mm)
  • 15.0
Mounting type
  • To screw
Connectic
  • Male
Connector
  • PLug CEE 7/7
Contacts Material (Connector)
  • Copper Alloy
Contacts Plating (Connector)
  • Nickel
Rated current (A)
  • 10.0
12 reviews
surprenante !!!
Bonsoir , j ai testé cette schuko sur ma platine cd ,belle transparence ,rapidité ,neutralité !!! niveau d une bals73 !! le top pour le prix
This review has been posted for Schuko Type E/F Power Connector Mennekes 230V Ø15mm
qualité prix magique
Bonsoir ,schuko mennekes sur ma platine cd avec du belden et iec c15 ncf , tres rapide,clair , neutre , bonne finition , pour des systeme un peu lent sombre ,elle est parfaite !! franck
Très bonne prise
Prise d'excellente qualité, RAS pour le prix payé.
Très bien
Très bon rapport qualité prix, ras
Bon produit
Très bon produit utilisé pour remplacer une prise uk
