SOMMERCABLE Schuko Type E/F Power Connector 16A IP54 Ø13mm
This robust and affordable Schuko power connector from Sommercable will allow you to design quality power cables at a low price. It accepts cable diameters up to 13mm and is easy to assemble with a screw-on system, no soldering required.
Reference : 16460
3,90 €tax incl.
3,25 € tax excl.
Sommercable Schuko Connector
16A IP54 Ø13mm
Sommercable Connecteur Schuko 16A IP54 Ø13mm
Product typeMale Schuko connector
Max cable diameterØ13mm
Max conductors section2.5mm²
Body materialHard rubber
Mounting typeTo screw
Voltage / Current230V 16A
DimensionsØ42 x 84mm
Max cable diameter (mm)13.0
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
Top du top !!
Une fois la vis inox retirée, la prise s'ouvre sans forcer.
On peut y visser 3 fils de grosse section (j'ai du power câble 4 mm2).
Le diamètre externe de mon câble est de 15 mm2 est ça rentre !!
Superbe prise secteur, c'est du Sommercable, c'est tout dire.
This review has been posted for SOMMERCABLE Schuko Type E/F Power Connector 16A IP54 Ø13mm
This robust and affordable Schuko power connector from Sommercable will allow you to design quality power cables at a low price. It accepts cable...
