VIBORG VE502 Schuko Type E/F Power Connector Pure Copper Ø20mm
This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal.
Reference : 13166
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 22-04-2025.
Viborg VE502
Schuko Power Connector Pure Copper Ø 20mm
Viborg VE502 Connecteur secteur Schuko Cuivre Pur Ø 20mm
This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal. In addition, this connector is able to accommodate cables up to 20mm in diameter and will therefore be suitable for both "classic" cables and HiFi cables with a larger diameter. Finally, the connector is covered with an Aluminium alloy body. This allows both to offer the connector a beautiful design but above all to limit EMI / RFI interference that could damage the signal and therefore audio reproduction.
Connector typeMale Schuko
Contacts materialPure copper
Voltage / Current250V AC / 16A
Maximum accepted cable diameterØ 20mm
Max. conductor diameter / cross-section4mm / 12,5mm²
Dimensions98.6 x 40mm
ScrewHexa / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
9 reviews
excellente qualité
Finition et qualité du produit
This review has been posted for VIBORG VE502 Schuko Type E/F Power Connector Pure Copper Ø20mm
excellente finition
excellente produit, finition exemplaire, esthétique, en cuivre pur ! malheureusement un peut trop chère des que l'on sort du classique boitier en plastique
Superbe
J'en mets sur tout mes câbles secteurs. Avant j'étais sur la première version, mais là c'est une autre histoire, on va un peu plus loin. Puis question esthétique, c'est quand même autre chose
Au top!!
Que dire de plus que woww!! superbe merci
Top quality Plug
Outstanding build quality and good construction. This is the best sounding Schuko plug i have tested so far. It sounds smooth, natural and organic with a lot of bass power. No harshness or edgy sibilants like some silver or rhodium plated plugs of other brands. Excellent combination with the Yarbo cable.
This Schuko Viborg VE502G male power connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good...
