VIBORG VE502G Schuko Type E/F Power Connector Silver / Gold 24k Plated Pure Copper Ø20mm
This Schuko Viborg VE502G male power connector is ideal for creating high quality power cables. It uses very good components, allowing both to promote conductivity but also to offer this connector a very good longevity. The contacts are made of pure Copper with triple plating: OFC Copper, Silver, 24k Gold.
4.8 / 5
Reference : 13164
65,90 €tax incl.
54,92 € tax excl.
Shipping date: 23-04-2025.
Viborg VE502G
Schuko Power Connector Silver / Gold 24k Plated Pure Copper Ø 20mm
Viborg VE502G Connecteur secteur Schuko Cuivre Pur Plaqué Argent / Or 24k Ø 20mm
This Schuko powerc connector Viborg VE502G is ideal for creating high quality power cables. It uses very good components, allowing both to promote conductivity but also to offer this connector a very good longevity. The contacts are made of pure Copper with triple plating: OFC Copper, Silver, 24k Gold. In addition, this connector is able to accommodate cables up to 20mm in diameter and will therefore be suitable for both "classic" cables and HiFi cables with a larger diameter. Finally, the connector is covered with an Aluminium alloy body. This allows both to offer the connector a beautiful design but above all to limit EMI / RFI interference that could damage the signal and therefore audio reproduction.
Connector typeMale schuko
Contacts materialPure copper
Contacts plating1. OFC Copper
2. Silver
3. Gold 24k
Max cable diameterØ 20mm
Max. conductor diameter / cross-section4mm / 12,5mm²
Voltage / Current250V AC / 16A
Dimensions98.6 x 40mm
ScrewHexa / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
14 reviews
Great value
Really impressed with the cost vs build quality of the Viborg connectors.
This review has been posted for VIBORG VE502G Schuko Type E/F Power Connector Silver / Gold 24k Plated Pure Copper Ø20mm
prise secteur solide et bien conçue
Cette prise Viborg est un très bon produit à l'esthétique réussie, comme ses con-soeurs le montage respire la qualité et la facilité. Cette prise schuko n'est pas la plus détaillée mais elle est à mon sens très neutre avec de belles qualités sonores. Pour la booster je conseille de l'associer avec une prise IEC ETI legato. Le mariage reste neutre mais gagne fortement en transparence.
Belles qualités
Montée sur un TCS31avec une IEC 50 NCF. Le résultat est un câble vraiment exceptionnel, sur mon DAC. Mise en remplacement d’une shucko Charlin. Il y a une petite amélioration en terme de contrôle: grave encore mieux tenu, équilibre général.
connecteur de qualité
J'ai réalisé 3 cordons secteur avec les connecteurs VIBORG VE502G shuko et connecteurs VIBORG VF502G iec, ainsi que du câble OYAIDE VONDITA .
Les connecteurs sont de qualité et acceptent même des câbles de forte section.
le premier cordon alimente un distributeur secteur AUDIOPHONICS MPC6V2, le second mon lecteur et le troisième mon préamplificateur.
Je n'avais auparavant que de simples câbles et multiprise, effectivement le son de ma chaine s'est améliorer à tous les niveaux, un voile se lève.
keep clear from signal wires
I have this Supra AC sensor device to measure if an AC cable or device radiates an electric field. These Viborg plugs radiate almost the same as a freeby cable. On a good isolated cable I measure nothing from end to end.
 (3)
This Schuko Viborg VE502G male power connector is ideal for creating high quality power cables. It uses very good components, allowing both to...
