VIBORG VE503 Schuko Type E/F Power Connector Pure Copper Ø19mm
The Schuko Viborg VE503 connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The contacts of the connector are made of pure Copper, a material that ensures excellent electrical conductivity.
Reference : 14315
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 22-04-2025.
Viborg VE503
Power Connector Schuko Pure Copper Ø19mm
Viborg VE503 Connecteur Secteur Schuko Cuivre Pur Ø19mm
The Schuko Viborg VE503 connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi system. The contacts of the connector are made of pure Copper, a material that ensures excellent electrical conductivity. The body of the connector is made of Bayer-2805 Polycarbonate. The conductors are simply mounted in the connector by means of a screw-on system that holds the conductors firmly in place.
Product typeSchuko connector
Contacts materialPure Copper
Body and contacts support materialPolycarbonate Bayer-2805
Mounting typeTo screw (Hex screws)
Max conductors diameterØ4.5mm
Min/Max cable diameterØ6mm / Ø19mm
Voltage / Current250VAC 16A
Total dimensions90 x Ø40mm
Max cable diameter (mm)19.0
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
3 reviews
Très beaux connecteurs en cuivre pure
Fabrication soignée du plus bel effet, en attente d'utilisation car pas encore montés.
This review has been posted for VIBORG VE503 Schuko Type E/F Power Connector Pure Copper Ø19mm
satisfied with the upgrade
I've purchased together with VIBORG VF503 IEC C15 Pure Copper Connector Ø19mm, and install it on an Elephant cable, to replace the power cable of a power amplifer. The results are: more defined bass, overall natural musical sound, wormer, separated voice, distinctive instruments. A better stereo imagine and increased soundstage on all axes. Very satisfied with the upgrade
Excellent produit...
J'ai reçu l'article dans une petite boîte, le tout accompagnée d'une petite clé allen pour les borniers du connecteur.
Le plastique autour de la fiche laisse une impression de "fragilité" mais le produit reste qualitatif.
J'ai associé ce connecteur Schuko au connecteur IEC de la même marque et aux câbles Neotech UP-OCC Cuivre ; Et le gain est au rendez-vous : plus aéré et plus précis.
Je voulais avoir 100% de cuivre depuis mon transfo d'isolement à mon équipement hifi et je ne regrette clairement pas mon investissement.
The Schuko Viborg VE503 connector offers excellent design quality and will allow you to design high-end mains cables to properly power your HiFi...
