VIBORG VE503S Schuko Type E/F Power Connector Silver Plated Pure Copper Ø19mm
This high-end Schuko Viborg VE503S mains connector uses high-quality materials to provide the best possible electrical conductivity. Thus, the contacts are made of pure Copper and benefit from a double plating of OFC Copper and Silver. The body is made of a particularly resistant polycarbonate, Bayer Makrolon 2805. The assembly is extremely simple with a screw system, so no soldering is required. The connector accepts cables with a diameter from Ø6mm to Ø19mm and conductors with a maximum diameter of Ø4.5mm.
Reference : 14579
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 24-04-2025.
Viborg VE503S
Power Connector Schuko Silver Plated Pure Copper Ø19mm
Viborg VE503S Connecteur Secteur Schuko Cuivre Pur Plaqué Argent Ø19mm
Technical characterisics
Product typePower connector
Connector typeMale Schuko
Cable external diameterØ6mm - Ø19mm
Diamètre conducteur max.Ø4.5mm
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Body materialBayer Makrolon 2805
Connection typeTo screws
Dimensions70 x 40mm
Total length90mm
Voltage / Current250VAC 16A
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
4 reviews
bon rapport qualité prix
Fait le job pour les petits budgets, ne peut pas rivaliser avec du furutech FI 38 mais qui est tout de même deux fois plus cher.
This review has been posted for VIBORG VE503S Schuko Type E/F Power Connector Silver Plated Pure Copper Ø19mm
Superb value for money
I have these coupled to Oyaide Tunami cables and they are every bit as good as far more expensive connectors. Sound is very neutral and the connector does the job of passing the signal as cleanly as it can.
The clamping mechanism is also a lot more cable friendly than other manufacturers who charge a lot more for phosphor bronze than pure copper! Shame Viborg didn't apply the same clamping mechanism to the IEC version of this connector.
Great connector
Build and finish is excellent. The cable clamping is very cable friendly, unlike Furutech and others that splay heavy gauge cables and I use 10AWG cables.
As plugs go, they impart great air and spaciousness to the sound.
Top
Très belle prise d'une très bonne qualité de fabrication, très satisfait.
This high-end Schuko Viborg VE503S mains connector uses high-quality materials to provide the best possible electrical conductivity. Thus, the...
