VIBORG VE512 Schuko Type E/F Power Connector Pure Copper Ø20mm
The VE512 serie power connectors are designed to for high quality power cables assembly.
They have a robust clamping system which ensures great stability from 6 to 20mm⌀ and are therefore quite suitable for HiFi cables with a large diameter.
Reference : 17499
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 17-04-2025.
VIBORG VE512
A pure copper conductor (OFC Copper) ensures superior conductivity that will enhance the qualities of a well-built power-supply, benefiting all subsequent elements of the installation.
Finally, the assembly is protected by a lightweight aluminum housing with a elegant design. This material also limit any EMI / RFI interference that might impair the signal.
Technical Characteristics
Connector TypeSchuko male
Contact materialsPure copper
Max cable diameter6-20mmØ
Plating contactsOFC copper
Max conductors dimensionsDiameter: 4.5mm
Section: 15.90mm²
AWG: 5
Voltage / CurrentAC 250V / 16A
Dimensions79.5x40mm / Length 98.6mm
ScrewHex / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
The VE512 serie power connectors are designed to for high quality power cables assembly. They have a robust clamping system which ensures great...
