Connector Schuko Gold plated Cryo Treatment Ø 19mm Black
Wattgate, the international reference manufacturer of mains connectors, offers cryogenically treated Schuko connectors for improved conductivity. This robust fiberglass chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional power outlets.
With an insertion ring limiting the diameter to 19mm, and a cable clamp to complete the integration, the 360 Evo can easily accommodate cables with a large cross-section. The internal connection terminals also deserve attention: equipped with large fixing screws, and therefore not requiring any soldering, they are capable of receiving conductors of large diameter which they ensure a firm hold over a particularly large contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip.
Convenient connector
The connector contact points can accommodate large cables up to 8AWG. The screw system allows quick and easy assembly.
Smart design
The connector contacts are made of copper alloy and have large mounting holes, allowing cables up to 8AWG in diameter to be inserted.
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Connector type | Schuko |
Max cable diameter | 19mm |
Plated | Gold |
Acceptable cable section | 8 to 14AWG |
Current / Voltage | 16A / 250V AC |
Body material | Polycarbonate |
Cryo treatment | Yes - DCT |
Connection type | To screw |
Non magnetic materials | Yes |
Color | Black |
Dimensions | 7.5 x 3.8cm |
