YARBO GY-901 Schuko Type E/F Power Connector Red Copper Ø18mm
3.5 / 5
Reference : 8215
33,90 €tax incl.
28,25 € tax excl.
Shipping date: 13-05-2025.
Yarbo GY-901 Connecteur Schuko "Red Copper" Nouvelle version
  • Conçu pour un conducteur jusqu'à 6mm² de section
  • Approprié pour des câbles jusqu'à 18mm de diamètre
  • Contacts laiton placage "Red Copper"
  • Poids : 55 g
https://www.audiophonics.fr/images2/8215/8215_yarbo_connecteur-secteur_GY-901_1.jpg
https://www.audiophonics.fr/images2/8215/8215_yarbo_connecteur-secteur_GY-901_3.jpg
https://www.audiophonics.fr/images2/8215/8215_yarbo_connecteur-secteur_GY-901_4.jpg
https://www.audiophonics.fr/images2/8215/8215_yarbo_connecteur-secteur_GY-901_5.jpg
https://www.audiophonics.fr/images2/8215/8215_yarbo_connecteur-secteur_GY-901_2.jpg
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
4 reviews
Best souding plug for the money, and more
In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
This review has been posted for YARBO GY-901 Schuko Type E/F Power Connector Red Copper Ø18mm
Moyen très moyen
La prise elle même ne souffre pas de gros défaut sauf pour les vis de serrage des conducteurs réalisées dans un métal mou (cuivre ?) et qui ne permet absolument pas de serrer correctement la connexion.
Dommage
Fragile
Matériel correct qui souffre toutefois de deux défauts, les vis en métal mou déjà évoquées et un collier de serrage du câble fragile, dont le plastique ne résiste pas à trois serrages un peu fermes. Savoir aussi que "red copper" signifie laiton anodisé.
Au total, un peu léger pour le prix.
Fiche Yarbo Red Cooper
Je viens de réaliser un câble secteur avec cette fiche Schuko et L'IEC qui lui est associée .
Le petit bémol se situe au niveau de la vis de la connexion terre sur la fiche qui est facilement déformable sous l'action du tournevis , j'ai dû la remplacer . Sinon le reste est de très bonne fabrication .
