ARYLIC A50 FDA Amplifier STA326 WiFi DLNA AirPlay Bluetooth 2x80W 4 Ohm
The Arylic A50 is an FDA with many advantages, including its wireless and very complete network connectivity. It allows you to stream your files directly from your smartphone, tablet, computer or NAS, very easily and without getting off the couch.
4.0 / 5
Reference : 13491
159,00 €tax incl.
132,50 € tax excl.
This product has been replaced by the new version, the l'ARYLIC A50+ FDA Amplifier.
Arylic A50
FDA Amplifier STA326 WiFi DLNA AirPlay Bluetooth 2x50W 8 Ohm
ARYLIC A50 Amplificateur FDA STA326 WiFi DLNA AIrPlay Bluetooth 2x50W 8 Ohm
The Arylic A50 is an FDA with many advantages, including its wireless and very complete network connectivity. It allows you to stream your files directly from your smartphone, tablet, computer or NAS, very easily and without getting off the couch. Arylic pushes the concept to the limit since the device has no physical buttons, all controls are performed using the remote control provided or your smartphone.
Arylic S50 Pro Arylic S50 Pro
STA326
The amplification circuit of this A50 is based on a STA236 chip that allows to deliver 2x80W under 4 Ohm or 2x50W under 8 Ohm. It is also capable of supporting PCM sampling rates up to 24bit 195kHz for high quality listening. This chip also includes a noise reduction system for transparent sound and predefined equalizers and tone control, which will allow you to adjust the playback to your listening and system.
Connectivity & Supported protocols
The Arylic A50 therefore offers particularly complete wireless and network connectivity and makes it its flagship. The amplifier therefore supports WiFi, Ethernet and Bluetooth connections. It opens the doors to streaming and allows you to stream your music from your smartphone, tablet, computer or NAS. The device is delivered with two antennas, allowing to increase the maximum reception distance of the signal in Bluetooth and WiFi. The A50 also features stereo RCA input and output connectivity and a USB-A input for connecting a hard disk or USB stick. The RCA output allows the A50 to be used as a preamplifier.
As for supported protocols, the A50 is also well equipped since you can enjoy AirPlay, DLNA, UPnP, Spotify Connect or Qplay.
Dedicated application & Many services available
The amplifier can be controlled with your smartphone via a dedicated application or a third-party DLNA/UPnP application such as BubbleUPnP, iMediaShare or ArkMC UPnP. You will therefore be able to send files stored on your local network or in your home, or enjoy internet radios and streaming services such as Qobuz, Spotify, or Youtube. In addition, the A50 and its application also allows you to enjoy the multiroom with synchronization of the tracks of each room or independent playback in each room.
iEast Play, an alternative with official Qobuz support!
Application iEast Play
It is also possible to use the Arylic 4Stream application as an alternative, allowing remote playback control, high resolution file support, multiroom and support for DLNA, Airplay and Qplay protocols. It offers many reading features via an intuitive interface. In addition, this application supports the high definition streaming solution Qobuz. This is a point that will certainly appeal to audiophiles looking for quality files. Of course, the application also supports Spotify, Tidal, Napster, QQMusic, iHeartRadio, Pandora and web radios.
Remote control
Don't want to take out your smartphone to control the playback of your audio files? The Arylic A50 comes with an IR remote control. All you have to do is sit back and relax, press "Play" and enjoy your music. The remote control includes all the necessary controls, including volume, playback, equalizers and tone adjustment.
Arylic A50 Test by Qobuz (FR)
"This Arylic A50 Amplifier is also a network streamer with Qobuz Hi-Res support. It is pleasant to use and to listen after some spent on tuning the device."
Test Qobuz
Product typeFDA Amplifier
Amplifier chipSTA326
Power2x80W @ 4 Ohm, 20Hz-20kHz, THD=1%
2x50W @ 8 Ohm, 20Hz-20kHz, THD=1%
Impedance4-16 Ohm
SNR92dB
Sampling rate24bit 192kHz
InputsWLAN 2.4G 150Mb b/g/n
Ethernet RJ45
Bluetooth 4.2
1x RCA Line input
OutputsSpeaker terminal
Pre-out
Streaming protocolsDLNA, UPnP, AirPlay, Spotify Connect
Available audio sourceStreaming : Spotify, iHeartRadio, Tidal, TuneIn, Napster, QQ Music, Ximalaya...
Files stored on your smartphone / tablet
NAS
GENEral
Power supply24V 6A via Jack DC (Power supply included)
Dimensions120 x 113 x 39mm
Weight415g
ColorBlack and Silver
Package1x Arylic A50
2x Antennas
1x Power supply
1x 2 RCA to 2 RCA cable
1x 2 RCA to Jack 3.5mm cable
1x Remote control
1x User manual
1x Screwdriver
InputRJ45
InputWiFi
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Power (W)80.0
4 reviews
High Value for Money
Are you seeking for a low cost an alternative to Sonos Amp? Here it is! I used only with the app via wifi (non bluetooth or other) and it works great able also toi pilot in decent way A pair of B&W AM-1 on my terrace. A50 is hidden in a big box (3 times the tiny amp) and is working fine. I reccomend it
This review has been posted for ARYLIC A50 FDA Amplifier STA326 WiFi DLNA AirPlay Bluetooth 2x80W 4 Ohm
Arylic A50
A state of the art wifi amplifier with high quality hifi performance. Low power consuming and automatic switch off when no audio signal.
Unfortunately bluetooth 4.2 instead of 5.0.
Audiosonics send the package in shorttime and good conditions to the Netherlands.
I am very satisfied with the A50 and Audiosonics.
Déception
Acheté en complément d'un SMSL AD18 sur une paire d'enceintes FH.
Grosse déception je dois dire. Il y a du souffle en bluetooth et il ne tient pas la comparaison (via Qobuz) en dynamique et précision (même après calibrage)
Quel dommage qu'on ne puisse pas également le brancher en USB directement sur le PC (en tout cas cela ne fonctionne pas sur le mien).
très bien, mais pas d'arborescence des dossiers en USB
En utilisation depuis peu. Donc trop tôt.
Cependant cela semble très bien fonctionner.
La télécommande est un petit plus bien pratique.
Très bons conseils par mail. Expédié très rapidement.
Peut se connecter à de nombreux services.
Seul bémol. Du moins avec l'application Muzo.
Un souci avec la lecture des morceaux stockés sur un disque dur en USB.
Il n'est pas possible de parcourir les répertoires. Tout est en vrac.
Vraiment pas pratique.
Peut être une autre application permet de le faire correctement?
Bonjour,
Cet appareil est également compatible avec la solution Ieast Play : https://play.google.com/store/apps/details?id=com.wifiaudio.iEastPlay&hl=fr
The Arylic A50 is an FDA with many advantages, including its wireless and very complete network connectivity. It allows you to stream your files...
