FX-AUDIO D302 PRO STA369 FDA Amplifier stereo 2x30W 4 Ohm Black
4.7 / 5
Reference : 11596
59,90 €tax incl.
49,92 € tax excl.
ST369 FX AUDIO D302PROThis FDA FX-AUDIO D302 PRO 24bit 192kHz Class D Amplifier combined with AKM AK4113 S / PDIF interface and Audio interface USB CM108 produces high-quality sound in a compact format.
This FDA amplifier has the characteristic of being a "Full Digital", ie the S / PDIF or USB signal is converted to I2S by the AK4113, and then directly amplified by the STA369.
Thus the number of digital processing reduces only to 3 steps instead of 5 to 6 on a conventional DAC allows unprecedented readability in this price range. It is also one of the few 100% digital FADs to have an analog input on gold-plated RCA connectors (with ADC PCM1808).
Its funderstandable aisle without multifunction display with dedicated buttons by function allows quick use without the need for a user manual.
Il has three digital inputs (USB, S / PDIF coaxial and Toslink optics).
Its USB Audio jack is also OTG compatible. So you can plug in an Android smartphone.
It will prove to be the ideal companion for any digital source with little space on a desktop ready for a computer
Its ergonomics and compactness are notable'adds its added versatility to amazing sound quality at a democratic price.
Features:
  • S & PDIF Interface AKM AK4113
  • USB interface CM108 24bit / 48kHz
  • Amplifier Module STA369: 2 x 30W under 4 Ohm
  • Signal to Noise Ratio (SNR): 100dB
  • Frequency response: 20Hz - 20kHz
  • Distortion 0.06%
  • Acoustic high-level equalizer with volume knob (dual function)
  • Inputs: S / PDIF Optical Toslink, Coaxial and USB-B)/ Li>
  • Stereo Analog Inputs on RCA Plated Gold (PCM1808)
  • Outputs HP: On screwed terminal blocks supporting the banana plugs 4mm
  • Headphone output on 3.5mm jack (amplifier NE5532)
  • Power supply 15V 4A included with 5.5 / 2.1 jack
  • Dimensions (WxDxH) : 133 x 133 x 36.5mm
  • Weight: 700g
  • Power supply included
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipSTA369
Power (W)30.0
27 reviews
après 2 ans 1/2
Installé en décembre 2019 entre
Qobuz 24 bits / 96kHz sur pc spdif et
une paire d'Elipson bs302 filtres refaits
en écoute de proximité.
Excellent, grave ferme, définition, scène sonore, etc.
Derrière, à 3m, il y a une paire de Magnepan MG 1,5 QR
sur un bloc stéréo AUDIOPHONICS MPA-S125NC
pour une écoute « auditorium ».
Je peux passer de l'un à l'autre, depuis mon siège l'écoute reste cohérente.
This review has been posted for FX-AUDIO D302 PRO STA369 FDA Amplifier stereo 2x30W 4 Ohm Black
Excellent choix
Encore mieux que sur le plan. Juste ce qu'il faut, là où il faut. Qualité sonore tout à fait convaincante sur des enceintes Focal SIB Evo 2.0.
rapport qualité prix incroyable
léger, puissant, qualitatif, à ce prix c'est imbattable
Bonnes impressions à chaud
Reçu ce jour, premier test vite fait sur des enceintes colonne Monitor Audio en attendant de recevoir les petites Eltax Monitor 1 qui lui sont promises : l'ampli fonctionne bien, même s'il peine à faire bouger les colonnes (ce qui est normal), surtout dans les basses.
La qualité de fabrication semble sérieuse. J'ai branché mon Xbox One S en optique et mon PC en USB (immédiatement reconnu) avec le câble fourni (moi qui pensais devoir en acheter un...). Tout fonctionne.
Avis partiel et temporaire donc, puisque je ne les ai pas encore VRAIMENT testées ni sur le long terme ni selon sa vocation définitive.
Mais cette première prise en main est très positive.
Bluffant
Ce petit amplificateur est très surprenant. Je l'ai installé à la place d'une grosse chaîne Hifi Pionneer intégrée dont il ne restait de valide que la partie ampli. Branché sur les enceintes de la même marque, le résultat est équivalent. Pour l'instant, je l'utilise pour le son de la TV et un lecteur de CD/DVD Blue-ray, les 2 sur l'entrée RCA via un commutateur.
Je n'ai pas encore eu la possibilité de tester les autres entrées.
Pour le prix, ce serait dommage de s'en priver.
Seul petit reproche : absence de repère sur le niveau de basse, aigu ou volume sur lequel est réglé le potentiomètre qui sert pour ces trois fonctions.
