FX-AUDIO D502 Amplifier FDA TAS5342A 2x60W + Subwoofer output 4 Ohm
With the D502, FX-Audio offers a complete, powerful Full Digital Amplifier (FDA) at a contained price. Equipped with complete connectivity, quality components, a beautiful screen and high / low settings, it will offer a rich and precise sound reproduction.
4.3 / 5
Reference : 13196
79,00 €tax incl.
65,83 € tax excl.
FX-Audio D502
FDA Amplifier Subwoofer Output TAS5342 2x40W 8 Ohm
FX-Audio D502 Amplificateur FDA Sortie Subwoofer TAS5342 2x45W 8 Ohm
FX-Audio D502 TAS5342
Efficient TAS5342 amplifier chip
The amplifier stage of the D502 is based on a high performance TI TAS5342 chip. This allows to deliver 2x40W under 8 Ohm or 2x60W under 4 Ohm while ensuring a low noise and distortion rate. Power that will allow you to combine the amplifier with many speakers, especially since the D502 offers a high efficiency over 90%.
In addition, the chip incorporates a complete protection system protecting the device from short circuits, overloads, undervoltage, excessive temperatures or loss of PWM signal.
High precision
The Cirrus Logic CS8422 chip is a 24-bit asynchronous sampling rate converter that also incorporates an SPDIF interface. The CS8422 allows synchronization with the Master Clock for perfect synchronization and therefore an ultra weak jitter.
FX-Audio D502 CS8422
Insérer texte alternatif ici
SA9023 USB Interface
So that you can connect a USB device like a smartphone for example, the D502 offers a Micro USB input. Behind this plug is a SA9023 USB interface chip, supporting sampling rates up to 24bit 96kHz. A chip that has already proven itself in many audio devices.
Subwoofer output with NE5532 AOP
The NE5532 is an efficient dual operational amplifier. It offers good performance in terms of noise, high gain, low distortion, high scanning speed and numerous protections. In the case of the D502, this chip handles the subwoofer output.
FX-Audio AOP NE5532
FX-Audio D502 Télécommande
Remote control
FX-Audio comes with its FDA IR remote control to control the amplifier and all its features. So, no need to get up to turn on the unit, adjust the volume, change source or adjust the bass and treble.
Front panel
FX-Audio D502 Face avant
1Power ON/OFF / Input selection
2Volume +- / Treble - Bass parameter
3Sampling rate
4OLED
Back panel
FX-Audio D502 Face arrière
1Micro USB input
2Aux Input
3Optical input
4Coaxial input
5Subwoofer output
6Speaker output (L/R)
724V 4A Power supply
Device typeFDA
Inputs1x Micro USB
1x AUX
1x Optical
1x Coaxial
Outputs1x Subwoofer
1x Speaker terminals (R/L)
Sampling rateUSB : 24bit 96kHz
Optical / Coaxial : 24bit 192kHz
THD0.04%
Sensitivity98dB
Impedance4-8 Ohm
Power2x60W @ 4 Ohm
2x40W @ 8 Ohm
Components
Amplifier chipTAS5342
USB InterfaceSA9023
PWM ProcessorTAS5508C
Sampling rate converterCS8422
Subwoofer AOPNE5532
Power supply24V 4A
Dimensions128 x 133 x 33mm
Weight1.1kg
Package1x D502
1x Power supply
1x User manual
1x Remote control
InputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Power (W)40.0
3 reviews
Un bon petit ampli
Bonne ampli compte-tenu du prix avec suffisamment de puissance et en plus il prend vraiment pas de place, pratique pour le mettre à côté de la télé.
This review has been posted for FX-AUDIO D502 Amplifier FDA TAS5342A 2x60W + Subwoofer output 4 Ohm
Il ne faut pas avoir eu de FDA avec un Chip ST326 avant...
Tout d’abords merci à Audiophonics pour nous permettre de tester tous ces petits amplis à des prix compétitifs.
Je voulais essayer un Chip Texas TAS5342 car je disposais de plusieurs FDA à base de Chip StMicro ST326 et après avoir lu tout et son contraire je voulais me faire mon avis. Côté fabricant, j'avais confiance en Fx-Audio car j'étais enchanté par son modèle D802.
Mon environnement : En source, un Raspberry Pi sous Volumio2 avec une carte Digi. En sortie, des Qacoustics Concept 20 et un caisson de basse Elipson Planet Sub.
J’ai ressenti une grosse différence avec le Fx-Audio D802 ou le Sabaj A3 sur toutes les fréquences (Basses, Medium, Aigus) et un rendu vraiment moins riche à mes oreilles. Bref dans ma configuration, il ne faut pas avoir eu avant un FDA à base de ST326. J'aurai testé ce D502 après mon Yamaha, le résultat m'aurait sans doute convaincu.
Je ne vais pas renvoyer ce Fx-Audio D502, il vient de prendre la place d'un D802 qui était dans la voiture et que je préfère conserver pour une éventuelle panne sur mon système principal. Avec des HP à 50€ ça passe suffisamment bien, par ailleurs le méchant poc qu’il envoie à la mise sous tension ne me fait plus peur !
FX Audio - Top en qualité prix
Bonjour,
Il y a 3 semaines, j'ai acheté le FX Audio D502.
Je l'ai associé au péampli DP02 & waouw c'est le pied !
Mes enceintes sont des satellites "JBL Contrôle" (re-câblées - Monster cable)
Le caisson basse est un "Triangle Météor 10 Tc" le tout avec les meilleurs câblages en interconnections audiophonics.
C'est véritablement d'une clarté & d'une transparence sonore formidable... !
Un régal pour toute écoute musicale.
Tout cela pour un rapport qualité prix hors concurrence.
Merci à tout le bon suivi Audiophonics.
Que votre succès continue encore, encore, encore... & toujours.
Bien à vous,
With the D502, FX-Audio offers a complete, powerful Full Digital Amplifier (FDA) at a contained price. Equipped with complete connectivity, quality...
