FX-AUDIO D802C PRO Amplifier FDA Bluetooth 5.0 AptX HD NFC Class D STA326 2x80W 4 Ohm Silver
The Pro version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model.
This amplifier is a very comprehensive tool that comes standard with a 192kHz 24bit digital to analog converter associated with an S / PDIF interface AKM AK4113, an ADC Wolfson WM88782S and Audio / DSP VIA VT1630A interface.
4.3 / 5
Reference : 12851
149,00 €tax incl.
124,17 € tax excl.
Full-Digital Amplifier Pro D802C
FDA-8Ω 2x50W 24bit / 192kHz STA326 / AK4113 / CM6642
Amp FDA D802CPRO
The PRO version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model.
An increasingly comprehensive connectivity
connectivity D802C
With its wide range of functionality and highly developed connectivity, the D802C Pro Audio at FX has all the assets to become a sound performance system the keystone.
The D802CPRO said amplifier is a "Full Digital" ie the S / PDIF signal is converted into I2s by AK4113, then directly amplified by a digital audio interface STA326. To do this, it has three digital inputs USB, S / PDIF coaxial and optical Toslink.
This team is also a stereo RCA auxiliary input and a USB audio jack supports OTG. We can connect him an Android smartphone.
Bluetooth 5.0
Chip Bluetooth 4.2
Unlike its predecessor, the PRO model embeds a QCC3034 AptX HD chip. It is therefore compatible with the latest versions of the Bluetooth protocol and works with the 5.0 standard. Wireless connectivity thus gains in performance and speed.
This standard is also less energy, which means that use with a mobile reader (like eg smartphone) consume less battery while ensuring a stable and accurate digital stream.
CM6642 Chip High Speed ​​USB - audio class
CM6642 chip
The control chip / CM6642 conversion can work with resolutions up to 24 bit / 192kHz.
This chip natively supports decoding audio and has interesting specifications codecs for the general sound quality of the device (SNR and THD + N ≥100dB @ 1kHz ≤-85dB ≤0.005%
To facilitate installation, compatibility, and avoid wasting time on the software configuration, this amplifier requires no driver to operate. The USB input is automatically recognized by all devices. Including smartphones also benefit from OTG support.
Control panel and volume knob
volume button and screen
This amplifier offers a neat control interface. There is a power-on button, a select button, a rotary volume control and a backlit control panel ..
For ease and comfort, it can also be controlled remotely via a remote control to a receiver I / R on the front.
Alternatively, the traditional interface is complete enough to let the onscreen user make their own settings with ease. It is even possible to specify an equalizer.
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
TypeFull Digital Amplifier
Power Output4Ω: 2x80W
8Ω: 2x50W
Supported sampling rates (max)24bit 192kHz
InputsBluetooth, Auxiliary, Optical, Coaxial, USB
OutputPregnant R + L
Impedance4-8Ω
THD0.09% (± 0.2dB)
SNR92dB
Interface controlRemote control / Control Panel
DC power supply32V 5A (supplied)
Weight1.25kg
Dimensions17.8x11.6x3.5 cm
ViewingDigital display (OLED) - with sample rate
Frequency response18Hz - 22kHz
ClockHigh accuracy
Remote SupportYes (IR) - (supplied without its CR2032)
Audio / DSP controllerVIA VT 1630A
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipSTA326
Power (W)50.0
Remote ControlYes
6 reviews
Souffle pendant les silences
Ampli bien fini sur le plan esthétique . Je ne suis clairement pas audiophile mais, comme indiqué dans la description, cet ampli présente un souffle notable pendant les silences. La mention n'était cependant pas présente sur le site lorsque j'ai acheté cet article en 2018. À éviter si vous cherchez un tant soit peu un confort d'écoute. Je m'en suis rendu compte en le comparant à un autre FDA. Étonnant que ce produit jouisse d'une telle notoriété avec un tel défaut.
Dans la même catégorie le SMSL AD-18 est bien plus agréable (bien qu'il faille changer l'alimentation qui siffle).
This review has been posted for FX-AUDIO D802C PRO Amplifier FDA Bluetooth 5.0 AptX HD NFC Class D STA326 2x80W 4 Ohm Silver
Compact et performant
En remplacement d'un appareil du même type. Performant et complet avec sa télécommande et son alimentation.
Petit bémol le contact bluetooth se coupe dés le moindre obstacle. La télécommande n'a pas d’accès à la fonction auxiliaire, ni bluetooth.
que du bon!
livraison ok. produit correspondant à mes attentes avec des basses ,des aigus en veux tu en voila. de la puissance suffisante. possibilités de différents réglages via l'équaliseur. tres bon rapport qualité prix.
je recommande cet ampli
Excellent...
Reçu début septembre, Colis livré à date prévu et très bien emballé. Rapport qualité prix imbattable. Fonction Bluetooth excellent ( essais à + 10 M concluant sans perte ). Connectique complète. Encombrement mini. Parfait pour mon système d'enceintes Bose Accoustimass 3. Seul Bemol : la fonction Hifi ( Direct source ) n'est pas présente dès l'allumage et donc petite manip. en plus.
D802C
parfait !
The Pro version for D802C improves Bluetooth module (QCC3034) and a gains a more efficient USB chip CM6422 than its previous model. This...
