SMSL AD18 V3.1 Digital Amplifier Bluetooth NFC TAS5342A 2x 70W + Subwoofer out / 4 Ohm
The SMSL AD18 V3 is the FDA Full Digital Amplifier par excellence. Providing high-definition melodic sound from both Bluetooth 4.2 and 242kHz USB 24bit, it also has a subwoofer active subwoofer output that delivers unbeatable stereo audio for even speakers.
4.7 / 5
Reference : 11498
129,00 €tax incl.
107,50 € tax excl.
SMSL AD18 V3.1
FDA Amplifier NFC TAS5342A 2x70W Subwoofer Output 4Ω
SMSL AD18 Amplificateur FDA
The SMSL AD18 comes back to us in V3 version with this time an integrated Subwoofer output, and the possibility to adjust the brightness of the screen (DIMMER). The Subwoofer output is accessible via the 3.5mm jack port at the base for Coaxial / Optical input. As shown in the diagram below:
smsl ad18
Despite the fact that it is the same connector, you can use the Coax / OPTI1 input and the Subwoofer output simultaneously with a jack to RCA cable (mixed or female) like this one:
smsl ad18
You can use this adapter to use coaxial and subwoofer : 3.5mm stereo male to 2x RCA female jack adapter cable 15cm
This adapter is also compatible: 3.5mm stereo male to RCA female stereo jack adapter
You can also use this adapter if you need only coaxial intput :
Jack to RCA adapter Coaxial AD18
SMSL AD18 is part of the new generation of FDA Full Digital Amplifier. It uses the high technology TAS5508C and TAS5342 chips using Texas Instrument's Digital Pure Path process. With a compact design it will bring a high resolution for the music lover who wants to combine compactness and high audio quality.
This amplifier has the characteristic of being a "Full Digital" i. e. that the S/PDIF or USB signal is converted to I2s and then directly amplified by the torque TAS5508C and TAS5342. The path of the digital signal thus simplified allows an astonishing quality of restitution of this category of apparatus.
The Bluetooth BT4.2 NFC Bluetooth format input allows you to take advantage of the qualities of the SMSL AD18 by offering better quality wireless playback for compatible iPad, iPhone, iOS, tablets and Android smartphones. (maximum distances 10m in close surroundings without obstacles).
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass tuning, treble, etc.).
It will be the ideal companion for any digital wireless or cordless source. Its ergonomics and compactness are not inconsiderable assets, to which is added its versatility thanks to its 1.44 colour TFT display, which precisely indicates each function.
To connect a coaxial cable to the AD18's Coaxial input in 3.5mm Jack format, you can use this compatible adapter: 3.5mm male mono to female RCA jack adapter.
Warning: AAA battery for remote control not included. Available here: AAA GP Battery.
SPDIF InterfaceCS8422
USB InterfaceVT1620A (16bit 44.1kHz-192kHz, 24bit 44.1kHz-96kHz)
DisplayColor Screen TFT 1.44"
4.2 NFC Bluetooth InterfaceCSR A64215 A11u
FDA ControllerTAS5508C
Amplifier moduleTAS5342A
Amplifier power2 x 70W at 4Ω (@THD 10% @24V)
2 x 40W at 8Ω (@THD 10% @24V)
Headphone amplifier chipMAX97220A
Double Op-AmpNE5532
THD0.04%
Frequency response18Hz - 22kHz
Digital equalizer7 positions (correction +/- 8dB)
Connectors
Digital inputsS/PDIF Optical Toslink
Mini Coaxial Optical
Micro USB-B
Digital inputsJack 3.5mm Stéréo
BluetoothBT4.2 (SNR 90dB)
HP OutputsScrew terminals, supports banana plugs 2.5mm
Subwoofer Output (SW)Jack 3.5mm "COAX / OPTI1" (unfiltered output)
Headphone outputAt 32Ω 53mW @ THD 0.04%
Power supplyPower supply included 24V 6.75A
Jack DC 5.5/2.5mm
(Linear power supply 24V 4A available)
(Do not supply with more than 24V)
Dimensions172 x 51 x 85mm
Weight1485g
AccessoriesMicro USB Cable
Power supply
Bluetooth Antenna
User manual
Remote
Remote controlIf remote controle does not respond, press the "A" key.
smsl ad18
smsl ad18
smsl ad18
smsl ad18smsl ad18
InputJack 3.5mm
OutputJack 6.35mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipTAS5342A
Power (W)40.0
Remote ControlYes
202 reviews
Suite AD18
Pour moi cet ampli fait chanter des Magnepan MG12 complété d'un caisson REL T Zéro.
Et des ATC SCM7...
This review has been posted for SMSL AD18 V3.1 Digital Amplifier Bluetooth NFC TAS5342A 2x 70W + Subwoofer out / 4 Ohm
Ampli Fda SMSL AD18
Que dire...
Il a tellement d'éloges.
C'est le troisième que j'achète.
Un pour moi deux que j'ai recommandé à une personne et un quatrième que j'ai fais acheté à mon frère.
Pas cher petit rapide pas de souffle diaboliquement précis assez puissant pour alimenter beaucoup d'enceintes à volume modéré.
Ça joue de la musique sans coloration sans transformation.
Tout ce que j'aime.
Ha ce petit AD18...
Il a du en envoyer au grenier des gros amplis 20 fois plus cher que lui.
Oui du son
Alors 0 étoile pour le son, beaucoup de choses,mais si vous cherchez une âme, de l’émotion ,il faut passer son chemin.
C'est juste pratique pour un jeune geek qui débute,pour sa console, la TV ou un smartphone.
La puissance annoncée est faussée si cela fait 70 W ,il en perd la moitié en route.
Je ne comprend pas tout ces avis à 5 étoiles. Vaut 10 fois mieux mettre 100 euros supplémentaires pour un ampli bas gamme de marques sérieuses, désolé mais en ce monde on en toujours que pour son argent et souvent moins ,ici ç’est même beaucoup moins .
Par contre toujours 5 étoiles au service Audiophonics !!!!
Étonnant
Vraiment étonnant le son sort de cette petite boîte D'accord je n'utilise pas l'alimentation fournie mais une alimentation audiophonics LPSU250 pourtant je pilote des JBL L65 Jubal pas facile a driver...alimenter par un très bon DAC ça fait des merveilles en Bluetooth également il y a moins de niveau forcément merci Audiophonics toujours au top sur le service et en plus vous pouvez trouver des connecteurs WAGO très efficaces pour raccorder vos fils d’enceintes
Bon ampli fda
Franchement, un rapport son/prix imbattable. Aucun bruit de fond, belle patate, bon son, franchement bien. Je ne suis pas de ceux qui parlent du son d'un ampli comme d'un grand vin. Je n'attends rien de plus d'un ampli que de faire ce qu'on lui demande. Il le fait parfaitement bien tant qu'on reste dans son terrain de jeu.
The SMSL AD18 V3 is the FDA Full Digital Amplifier par excellence. Providing high-definition melodic sound from both Bluetooth 4.2 and 242kHz USB...
